The Radeon RX 5700 XT Owners Thread.
@Kaapstad ty
Welcome and on TROH.:)
The Roll of Honour.
Date 08/08/2019, Make AMD 50th AE, Besty, Link
Date 07/08/2019, Make AMD 50th AE, willb1967, Link
Date 31/07/2019, Make AMD Reference, ernorator, Link
Date 31/07/2019, Make AMD Reference, Kevin Matthews, Link
Date 30/07/2019, Make AMD Reference, FiremanSam, Link
Date 25/07/2019, Make AMD Reference, xxalxx, Link
Date 25/07/2019, Make AMD 50th AE, brightside229, Link
Date 25/07/2019, Make AMD 50th AE, Panos, Link
Date 20/07/2019, Make AMD Reference, InvaderGIR, Link
Date 20/07/2019, Make AMD Reference, Aod, Link
Date 19/07/2019, Make AMD 50th AE, BOFH, Link
Date 18/07/2019, Make AMD Reference, gavinh87, Link
Date 17/07/2019, Make AMD 50th AE, LtMatt, Link
Date 14/07/2019, Make AMD Reference, bake73, Link
Date 12/07/2019, Make AMD 50th AE, jrodga2k5, Link
Date 11/07/2019, Make AMD Reference, LtMatt, Link
Date 11/07/2019, Make AMD Reference, docsonic, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Radeon RX 5700 XT.
My recently puchased 5700 xt is running very nicely, no system freezes or other oddities.
With one exception, in Rage 2 a specific light source produces some odd angular flashes that I don't recall seeing when playing on my 980.
Video of glitch -
I wondered if any other 5700 users had noticed similar? It doesn't look like a typical gpu artifact, perhaps driver related, or is it RMA time before it gets worse?
Video taken after a clean driver install with no settings touched in adrenaline.
I tried re-installing the drivers after using the AMD cleanup utility and the glitch remains.
Gigabyte X570 Aorus Elite
Ryzen 3600
16 GB Patriot Viper Steel 4000MHz clocked at 3733 C16
Corsair 750i PSU
Video of glitch -
Ryzen 3600
Corsair 750i PSU
I do not play Rage 2 unfortunately. But all the other games I play have no issue.
Have you considered to make a custom game profile, if it doesn't exist, and run the game from there?
Heres my pic for TROH :D
The Roll of Honour.
Date 08/08/2019, Make AMD Reference, R3v4n, Link
Thank you for the suggestion. I have tried launching from a custom adrenaline profile using various adjustments to the AMD specific settings.
No difference as far as I could see, although I did notice that the "glitches" look like much larger versions of the sparks from the flare effect leading me to think
it is more likely to be a driver issue rather than a card fault.
Just tried MSI Kombustor artifact scanner using 7634 MB vram running for five minutes, (enough to make a brew) and it reported zero artifacts.
Video of glitch -
Ryzen 3600
Corsair 750i PSU
I don't have the game to test it myself however...
That doesn't look like artifacting to me, looks like a gfx glitch most likely just a glitch in the game.
Artifacts are like bubbles with funny colours/black dots/sparkles. That yellowish looking glitch is spiking out of an ingame effect with exactly the same colour.
See what other people think, but I'd say its the game not your GPU.
Use DDU in Safe Mode (thats important) and install the 19.7.3 without Relive.
Auto-overclock in Wattman chadding like a boss straight through 2200mhz.
2158mhz is about the edge of stability at 1.25mv.
I think you're right, I've had cards which had vram issues and the corruption was less in keeping with the game visuals and more like a spectrum loading screen.
Good idea. I followed you instructions and went straight into the game after the installing the earlier driver. Sadly the glitch persists.
I did find another video of Rage 2 running on a 5700xt, and it appears to show the same issue between 0:8 and 0:15 seconds.
I have submitted a report to AMD , maybe they can squash it.
Cheers for all the help.
