Wait. The gap only starts becoming significant at 2080S and above. The GTX 1080 is still a capable 4K card, but you do have to tweak settings. Maybe try 1800p more, instead of straight up 4K when in-game.
its aimed at 1440p, but i believe the vega cards are ok at 4k with a few settings turned down, so i suspect the 5700xt will be just fine.
if you want to play it completely safe go for a 2080, but imo they're horrifically over priced.
Take your pick /
GEFORCE RTX 2070 SUPER DUAL EVO OC 8192MB GDDR6 PCI-EXPRESS GRAPHICS CARD £529.99
RADEON RX 5700 XT DUAL EVO OC 8GB GDDR6 PCI-EXPRESS GRAPHICS CARD £428.99
Where? I'm old and blind, but not that blind.I gave you a very clear meta-analysis of a whole host of benchmarks.
Neck and neckApologies if posted already
https://www.anandtech.com/bench/product/2522?vs=2516
Trading blows with each other. If 10% equates to 3-7fps when you're already in the 80s then you're clutching at straws.
https://www.tweaktown.com/articles/9054/amd-radeon-rx-5700-xt-benchmarked-3440x1440/index5.html
Holding its own in 1440 Ultrawide
Neck and neck
https://www.tomshardware.com/reviews/amd-radeon-rx_5700-rx_5700_xt,6216-2.html
https://www.tomshardware.com/reviews/amd-radeon-rx_5700-rx_5700_xt,6216-3.html
Nope, still in there.
And this is with the messy, broken drivers too. Only going to get better.
And enough of the "pom poms" bull, OK? Have a conversation, chew the fat over differing opinions or jog the f on.
Ah, gotcha.It was a nested link in the first post.
That's the crux of my argument: £50-70 is not marginal.But overall the 2070S is a higher performing card, and if the price difference is marginal surely it makes the most sense?
Can I go with option C: a returned reference 5700xt @$350?
Release is 13th apparentlyI've heard a rumour reviews are going up for AIB 5700/XTs on Monday. Bring 'em on.
£500 for the Strix 5700XT haha. No free lube with the ROG card.
Or the 4th option, a 2070s for $350
Pretty much every single AMD card in history has only gotten faster/better with each driver update
