The Radeon RX 5700 XT Owners Thread.
22 Nov 2009
Under the hot sun.
I think you're right, I've had cards which had vram issues and the corruption was less in keeping with the game visuals and more like a spectrum loading screen.
Good idea. I followed you instructions and went straight into the game after the installing the earlier driver. Sadly the glitch persists.
I did find another video of Rage 2 running on a 5700xt, and it appears to show the same issue between 0:8 and 0:15 seconds.
https://www.youtube.com/watch?v=BA6MQaYbQiA
I have submitted a report to AMD , maybe they can squash it.
Cheers for all the help.
Do you use some screen overlay? Some games eg WOT have issues with overlays, showing stuttering also. And is prominent when I change the sound volume or Discord with the group overlay
That issue had with V64, GTX1080Ti and 5700XT. Hence I do not use overlays except the one Windows 10 pop when changing sound.
8 Aug 2019
No overlays used. Not much on the system; clean windows 10 installation, appropriate drivers and some games.
Man of Honour
OP
21 May 2012
Dalek flagship
@Kaapstad
https://photos.app.goo.gl/ThFQQJjMEw4Ra9MPA
Only took me 10 days to post the image lol.
Edit: not that it posted correctly.
Welcome and on TROH.:)
The Roll of Honour.
Date 10/08/2019, Make AMD Reference, Potatowithearsontheside, Link
Date 08/08/2019, Make AMD Reference, R3v4n, Link
Date 08/08/2019, Make AMD 50th AE, Besty, Link
Date 07/08/2019, Make AMD 50th AE, willb1967, Link
Date 31/07/2019, Make AMD Reference, ernorator, Link
Date 31/07/2019, Make AMD Reference, Kevin Matthews, Link
Date 30/07/2019, Make AMD Reference, FiremanSam, Link
Date 25/07/2019, Make AMD Reference, xxalxx, Link
Date 25/07/2019, Make AMD 50th AE, brightside229, Link
Date 25/07/2019, Make AMD 50th AE, Panos, Link
Date 20/07/2019, Make AMD Reference, InvaderGIR, Link
Date 20/07/2019, Make AMD Reference, Aod, Link
Date 19/07/2019, Make AMD 50th AE, BOFH, Link
Date 18/07/2019, Make AMD Reference, gavinh87, Link
Date 17/07/2019, Make AMD 50th AE, LtMatt, Link
Date 14/07/2019, Make AMD Reference, bake73, Link
Date 12/07/2019, Make AMD 50th AE, jrodga2k5, Link
Date 11/07/2019, Make AMD Reference, LtMatt, Link
Date 11/07/2019, Make AMD Reference, docsonic, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Radeon RX 5700 XT.
16 Mar 2018
Hi,
I have an issue with my 5700. This morning the entire monitor screen started to snowfall !!!! I thought at first that it is unstable overclock, but it wasn't. I have just started AB, not applied any overclock. The snowfall started when I loaded a game. Timeline what happened:
1. Started the computer
2. Started AB (without changing any settings)
3. Started a game
4. Snowfall in the main menu of the game
5. Rebooting the computer => snowfall on the desktop and everywhere
6. Reboot in Safemod => no snowfall
7. DDU AMD driver remove
8. Installing the newest AMD drivers (****5 something)
9. Rebooting => no snowfall
10.Starting a game = no snowfall
11. Playing the game for some time = no snowfall
12. Applying my normal overclock with AB
13. Playing again the same game = snowfall started again
What do you think, is my RX 5700 for RMA?
Thank you!
18 Oct 2002
Hi,
3. Started a game
Thank you!
try a different monitor cable first
but yeah it’s probably an rma if that fails.
16 Mar 2018
I didn't have much time in the morning (had to go for work). But I think to try:
1. a different cable between the monitor and the GPU
2. a different port on them both
3. To move the GPU on the other PCI-Ex16 port
4. To put the second RX 5700 (it is in the box right now) in the same PCI-Ex16 port of the problematic GPU
5. To try to find out is it working fine without any overclock/undervolt
If any of the above does not solve the issue to RMA the GPU. But I am wondering, is it the same issue as it was with the first RTX cards when they came out on the market ?
20 Apr 2004
Oxford
same gaming experience for 200-300 euro less.
amazing card
Ignoring the 2070 super which is a fraction faster, also starts at £499 for custom cards, stock card is in the middle for the two bios's noise levels an consumes less power despite being on a bigger manufacturing process.
When it comes between picking between a 2070 super and a custom 5700xt its really down to what team you prefer.
Caporegime
1 Dec 2010
Welling, London
I dont want to sound like a moaner, but I think £500 is too much for the ASUS strix. Over a £100 more than reference cards, and the review shows there's only a few frames in it between the two.
Should have been around £450-460.
18 Oct 2002
not accusing any site of cheating results but one of my bugbears is that openrigs in airconditioned rooms are used far too often. there might be a few frames in it under those conditions but at 'normal' UK room temps and closed cases the difference may be higher.
