- 11 May 2007
- Surrey
And a sub thread for the items they send back/didn't keep.
Haha. We could take bets on keeps or returns.
I was thinking maybe balance and recoil not just sound. Whats the weight of that rifle, not sure if you hunt with it or just target shoot but its lethal to rabbits I'd betThe gun has a loud crack when shooting so the suppressor helps a little, but mostly for looks.
Thought I'd try the Mi Band 4... will likely be on the MM soon
Thought I'd try some cheap chinese knock off Airpods...
Completed a Strava challenge recently where I got a £50 voucher to use on Le Col, so got some £100 bib shorts for £50 (which I guess is closer to what they're actually worth). They do seem very nice though, nicely presented for sure!
I only hunt people with it as it's an airsoft gunI was thinking maybe balance and recoil not just sound. Whats the weight of that rifle, not sure if you hunt with it or just target shoot but its lethal to rabbits I'd bet
and the weight of it about 3.8KG.I wondered if you'd been hitting the gym or cycling lately. I've watched your youtube videos for a couple of years and you look so trim lately- no homo![]()
Ha ha thanks, yeah, today is my 5 month anniversary of eating better and cycling lots. 5 stone gone in 5 months! (There is a video about it on the 4 months anniversary on my channel)
Do you shoot noisy neighboursEven if it was a suppressed air rifle, what is the problem with that? I have one for pest control.
It's not ideal but not too bad either. The cabinet to the rear of the chair covers a multitude of sins (two double plug sockets, Home network connection and one of those new/large BT sockets). I also wanted the PC off the main desk. Compromise? Yes, a little but it's fine really.
Thanks. It's fully fitted so everything is flush to the wall/skirting.
So the cables from the PC are routed through conduit behind the skirting to the desk?
Are you able to swap any of them out?
The cables run through the conduit above the skirting. The fillers on the wall side of the units are removable so I can access the cables if necessary. A bit of a faff should that happen as I'd need to re-caulk if I were to remove and re-fit but it does give some flexibility should I need to change anything.
Can't see me needing to do that in the near future unless one of the cables fails.
Some new bedside cabinets, pictures and lamps (the latter bought a few weeks ago):
Yes, thank you. Much prefer it to suburbia!
Some new office chairs. Seem comfortable enough.
Is it me or are all the rooms and ceilings in your house painted all exactly the same colourThe cables run through the conduit above the skirting. The fillers on the wall side of the units are removable so I can access the cables if necessary. A bit of a faff should that happen as I'd need to re-caulk if I were to remove and re-fit but it does give some flexibility should I need to change anything.
snip
I said a splash of colour and massive contrast man, not brown and grey![]()
