Mines hitting 82 as well, but averaging 75-77. I'm using a Corsair H100i AIO cooler and I'm sure it's installed properly. Steedie's hitting high 70's-80's too.
I'm a little suspicious of the 61 result. I can only imagine it hitting that under 100% load if undervolted and cooled with a custom loop. Can't imagine any standard air or AIO cooler keeping it that cool.
What BIOS are you running? I have the same CPU and Board and after I updated the BIOS my boost has been capped at 4.3-4.4, it happily went to 4.6 before I updated the BIOS.Actually seen an improvement today. Now up to four cores hitting 4.6 when gaming.
I stayed with the shipped bios, F3.What BIOS are you running? I have the same CPU and Board and after I updated the BIOS my boost has been capped at 4.3-4.4, it happily went to 4.6 before I updated the BIOS.
Any chance you could back it up and share it ?I stayed with the shipped bios, F3.
Am I missing somit, every time I check OC site it still on Pre Oder.
So where are you buying this CPU
Just got a 3900X, installed it and first boot took a long time. CPU temp 36C idle, 67C cinebench, score = 3118. think mem is @ 2400. max clock reported @4569Mhz
it takes 1 minute 40 seconds to boot now, took < 10 seconds before?That's common, its just the BIOS recognising its not a Ryzen 1000 or a Ryzen 2000, its a Ryzen 3000, they all do it fist time instillation.
Just set mem to 3600 using xmp, should be cl17,18,18,38,56 but its @ cl18,18,18,38,85, t1 but it is 4*8 so...
It posts fine, its windows that takes 1:40 to load with the spinner spinning. maybe its a problem with the m.2?No that's not normal, after the first boot it shouldn't take more than 10 seconds to post.
My C:\ drive is an old SM951 m.2, its the AHCI version though, just tested it and it get 2GB/s read and 1.2GB/s write so should be ok. going to run an sc cmd to test for errors.
