- 16 Mar 2018
My issue is false positive !!!! I resolved it for 2 minutes
The issue comes from the way the GPU mounts in the case and the way HDMI cable connects to it. It seems that the card fits in my case HAF-X so tight that I cannot plug the HDMI cable into it. So I need to:
1. remove the side panel of the case
2. remove the screws that holds the GPU tight to the case (the cards hangs a little, because it is holding only on the PCI-E slot)
3. plug the cables that I need
4. get back the screws
5. close the side panel
I found and the root of the issue - two days ago I was removing my custom water cooling loop and to minimize the risk of damaging the GPU I decided to remove it from the case. And .... when I was returning it I forgot about this little specific cable plug in
I was so tired and just plugged the HDMI cable somehow...... and it was working for two days with no issues till this morning ...
post 681
681 AD is the year that my nation has been found
The issue comes from the way the GPU mounts in the case and the way HDMI cable connects to it. It seems that the card fits in my case HAF-X so tight that I cannot plug the HDMI cable into it. So I need to:1. remove the side panel of the case
post 681
