And pigs can fly![]()
Yeah, but we're not talking about parliament are we.
I've heard that fixes it, keep us updated man (I get the odd one too, came from a Vega) but not done re-install yet as cba.
Didn't fix it should could be an issue with the card itself
I had similar issues and I changed my PCIE slot from auto to Gen 3 and it seems to have fixed my issues.Didn't fix it should could be an issue with the card itself
The price in the USA is as expected, which means its one of 2 things. Our tax/exchange rate or price gouging because they can.
The hike is quite large, some of the custom cards are meant to be RRP. i.e circa £379.99.
The Red Devil Special ED varys wildy in price from £450 all the way up to £500 (RTX 2070 Super territory).
Can't be good for AMD. Supply and demand for the retailers though I guess.
Im attempting to steer well clear of new cards until cyberpunk launch, the pricing is really helping me xD
Yes its awful for AMD that their 5700Xt is virtually on par with a card that costs £100 more...
As for supply check out the thread on OCUk's reccomended 2070s...
It's like 1984 in this forum sometimes.
Eh?
Not sure how you read that, what I'm saying is the cards are great, but retailers have jacked up the price. Which means people could choose Nvidia instead when same price as RTX 2070 Super for example.
Whereas at RRP the 5700XT is a good choice. Prices are way over atm. So not great for AMD. It isn't their fault. Hopefully the prices settle soon.
Quick 2 questions,
Are these as fast as a 1080ti?
Which model will run quietest and has 0% fan when not is use?
I've picked up the Red Devil Special Edition for £459.99. Not cheap but there market is terrible at the moment. Alternatives were older tech, second hand with no warranty or spend £100+ more for a little more performance.
This seemed a good middle ground. Upgrade later to a 2080Ti level card.
Seems bonkers to me considering that £475 *has* been enough to get a 2070S.
Sure, an AIB 5700XT at ~£400 I'm behind as it sorts the caveats and the performance difference isn't that much for £75-100. But you're talking £15-40.
Each to their own though.
But all we're doing is encouraging the inflated prices.
Gaming noise levels with the default BIOS are incredible; only 31 dBA is a monumental improvement over the AMD reference card, making the Red Devil quieter than the majority of NVIDIA RTX custom-design cards at the same time. Once you switch to the "Quiet BIOS", the Red Devil goes even quieter—whisper quiet even when fully loaded, which is incredible. The second BIOS does run slightly lower voltage, clocks, and power limit, which suggests it is properly fine tuned for the capabilities of the cooler. I think this is the quietest AMD Radeon graphics card I ever tested, especially when you take its performance levels into account—good job, PowerColor!
