Just remembered check your tyre pressures as they were recommending 45 PSI for range but may have revised that down to 42 PSI to balance comfort. Mine were 40 when I checked so I'll check them with my calibrated gauge and go a few PSi higher.
Did anyone check there tyre PSI's on collection ?
Absolutely bonkers bit of kit, well worth the just over 2 year wait.
2 years well that just makes me feel even worse about my buying experience.
.As in he only decided to order one about 2 months ago and others have been waiting for 2 yearsBad in what reason?
As in he only decided to order one about 2 months ago and others have been waiting for 2 years![]()
What with all the silver & White cars/vans around your area
Hmm not even that long I'm embarrassed to say as I placed my order on the evening of the 7th August and picked my allocated car up 6 working days later on the 15th August. It was a rush to confirm the PCP, sell my i3 to cover the remaining deposit, confirm the insurance with LV and then take a day off and travel by train to West Drayton to pick it up!
More testing at 70 mph today and on ideal flat road conditions @ 16 DegC reduced consumption to 240 wh/mi so significantly less than my initial figures of ~275 wh/mi in the wet. Tyres set to 43 PSI all round.
If you hadn't realised the Model 3 has a dash cam feature that uses the front and side repeater cameras to record 3 streams. You'll need a half decent USB stick or SD (in adapter) to record the streams and not burn the device out.
Follow the guide below and simply populate one of the front USB ports and the dash cam operates automatically. That also enables the Sentry Mode but it does continually sap power even if it's a trickle. Sentry is activated manually when required.
Simple instructions are format device to Fat32 and create a directory called "TeslaCam".
https://teslatap.com/articles/usb-flash-drives-for-tesla-dashcam/
used an external SSD and bought a £4.99 app on my MacBook to replay the footage, works a treat. Already had swarms of kids around it at the supermarket!Lovely car @JamesM - Red is a cracking colour.
Looking like a good OcUK Fleet of Model 3's.
Just wish I'd have some indication of a delivery time or something. Does seem like a black hole at times......
Had the Tesla charger fitted yesterday. Think it maxes out at around 29 miles added per hour. Combined with the Octopus Energy EV tariff and 5p/kWh between 00:30 and 4:30 I should easily be able to keep the car topped up every few nights for a couple of £
Ordered the wireless charging pad and plan on getting the front bumper and lights wrapped next week for a bit of extra protection.
