 - 25 Jul 2019
Afraid to burst your bubble but the 5700XT isn't high end.
Nope, 2070, 5700 xt is high end
2080, and 2080 ti is enthusiast level.
Nice try.
Nice try.
I don't get the nice try lark. It's not a negative that it's not high end.
The 5700XT is mid range, it's size is the indication of this.
It's mid range at a higher tier price point. But it's performance is very good for what it is.
Here it is:
 I am not upsetIsn't it rather foolish risking your entire build due to the PSU?
Just a question for you though, why do you think its at risk?
PSU are some of the most overbuilt hardware you can get.
Just curious to where your train of thought on electrical subsystem thinks its a risk?
The older a PSU gets, the higher the risk of failure. I had a decade old PSU in storage, unused for years, kept well packed and dry, but it failed when a friend used it in his build. Luckily no damage done, but lesson well and truly learned for both of us!![]()
You haven't given a technical reason if I'm honest. What exactly is my PSU at risk from?
Personal vicissitudes, I suppose. That said I'm no expert on PSUs, but I believe the standards on these puppies were lower a decade ago. And granted it has likely run its course: https://en.m.wikipedia.org/wiki/Bathtub_curve
I'm not an electrical engineer mate, and I'm guessing neither are you? It's accepted that PSUs degrade over time, particularly with heavy use. Do you think people are careful for no reason?
Only issue with any of this is, what is the time frame that failure is supposed to be exhibited? Looking at that graph alone, the initial usage suggests thats when the bulk of the rate begins then starts to level off in a steady fashion.
Oh I'm not but if no ones an expert, can a claim like that be reliably made, everything degrades over time but at the same time, to think something will fail in 3 years and becomes a high risk from after that point seems senseless if anything, a scare monger from somewhere.
Only an electrical expert on these forums can really tell us the life expectancy of components like this.
Isolated PSU failures are all dandy. The problem is when you add the cumulative risk of damaging other components in the process. Just seems very unnecessary.
We all know failures is a very real thing in components, but you are actually avoiding the question, what would be the risk of my PSU failing and what sort of time frames do you expect them to fail at? or become a risk from?
Why isn't 20 years considered a point of risk?
