The aux would have to come from the monitor to the speakers.
The sound being carried from the HDMI
Just checking to make sure. All you need to do now is test it and see what happens.
The reason I've got it the way I do is so I have everything connected to TV and then it dishes the sound out to my amp via optical. Introducing switches takes away the simplicity.
A HDMI 2.0 splitter in the middle is potentially an option.
But an annoying one.
Now it says peak 3164MHz lol.Max.
Anyway, I set 1905MHz for 1013mv then played Forza Horizon 4 for hours on end. Peak clock 2294MHz. WTF?
Peak Power 153w, average 106w.
GPU averaged 64C, 69C max.
Well my Sapphire Pulse 5700XT has been dispatched and will be delivered tomorrow. I'm still on the 18.12.1. drivers so I'll have to DDU those and install the latest drivers which I'm not looking forward to TBH. I'll have a play with it over the weekend re under volting/overclocking and see what happens. I'm off all next week so I'll probably do a fresh install of Windows at some stage as I should have done this when I got my Ryzen 2700 to replace my 7700K. Bit lazy I suppose which I'll rectify next week.
I read the Igor Labs more power tool guide and he admits the fan curve in the latest drivers is plain broken and are very poorly designed so I think I'll just ignore wattman and tinker with the Trixx software which is what I did with my Fury card. Talking of my Fury card I found the receipt for £435.16 dated 7th Sept 2015 and I paid £439.99 for the Pulse card. I also paid £449 for my Vega 64 card on launch day in 2017 so the AMD prices have stayed fairly static if you ignore Radeon VII which wasn't supposed to be released anyway.
?Now it says peak 3164MHz lol.
How have they stayed static when the 5700XT's not in the same tier as the Vega 64 and Fury X?
Absolutely. The Fury card was pitched against the 980, the Vega card against the 1080 and now the 5700XT against the 2070 Super (similiar to the original 2080). So I would say all three are definitely in the same tier. Not sure if the Nvidia prices have done the same.
The 5700XT's a mid range GPU. It's not the Vega 64 successor.
As an owner of a Vega 64 Ref card, Vega 64 was really a mid range card disguised as a high end card and TBH without having to tweak it it was an absolute **** of ****. AMD flogged GCN to the death. Now with RDNA we can start again. Let's see where it takes us my Pulse arrives tomorrow and it will out perform my Vega 64 so what's not to like.
There was nothing mid range about Vega 64. It's twice the size of the 5700XT and had HBM.
Its default setting was absolutely crap, no doubt about it. But it was a high end card.
I like the 5700XT, but it's not high end.
.The 5700XT beats Vega 64 by a good margin so what is your problem? If Vega 64 was high end no matter the size of the die who gives a ****? HBM had that with my Fury as well and it did nothing at all and TBH I was disappointed with that but life goes on. ATM, excluding Vega VII which shouldn't have existed the 5700 XT is AMD's fastest card. Why can't you see that?
High end has to be defined relatively...there is only 4 cards that are faster (2070s(marginally)/Radeon 7(marginally)/2080s/2080ti). So with more below it than above it by that alone it can't be in the middle pack.
I'd class anything above 150 as mid range, above 300 and your getting into high end graphics cards, above 500 and it's almost certainly enthusiast grade. Above 1000 is complete lunacy.
It's a 5M cable.
Can't go any shorter.
The problem is that this was fine with the Vega 64.
There's no scope to change anything in my set up really.
I use a Corsair SP2500 with my Xonar STX for normal day to day with my 34" 144HZ over DP and that's fine as normal.
The 5700XT has introduced the issue as far as connecting to my TV goes though and then amp.
I also have this issue with a reference sapphire 5700xt linked to my LG tv 49inch. Sometimes the sound is fine. Sometimes it will cut out very say 20 seconds or so. I think I have a 3m cable hdmi
