Almost essential. Only ranks below having an SD card slot.
I still like the 16:10 ratio on the original Samsung Note, the current ratios on the Samsung phones and notes are ridiculous.
without conflating threads the s10 Eu exynos 3.5mm/codec are not meant to be very good, vs SD - anantech
Switching over to the Exynos Galaxy S10 however we’re seeing some pretty shocking results. The phone uses a Cirrus Logic CS47L93 audio codec chip which has actually been used in Exynos variants since the Galaxy S8. Unfortunately in recent years this was surpassed by Qualcomm’s audio chips, and in particular the Galaxy S10 suffers from a pretty bad implementation. Here we’re clearly seeing noise components that are not part of the reference 1KHz signal, with a particularly odd 250Hz component. The measurements were done in sequence with just re-plugging the input from the Snapdragon to the Exynos under the same conditions. Audio output level was calibrated at near -10dbV / 312.5mV RMS on both devices.
In practical terms, there is audible difference between the two as the Exynos unit sounds warmer (in a bad way) and more muffled. The Snapdragon achieves higher clarity and the sound stage appears wider. This was my subjective evaluation using the same Samsung’s included AKG headphones on both units, both having the same software audio settings.
I applaud Samsung for still including the 3.5mm headphone jack on the Galaxy S10 – however a big part of the world will unfortunately experience lesser audio quality on their model variants.
A unnecessary frustration from not having it, particularly at airports and on flights.
Yes. Turn on flight mode then turn on Bluetooth straight after.?
You can still use Bluetooth on flights when your phone is in aircraft mode
the monies being diverted elsewhere in the build.
I don't understand peoples frustration from not having one. Just leave the dongle connected to your headphones.. That's what I do and it's virtually the same. If I want to charge it, well I'll use wireless charging or get a splitter dongle and leave that connected instead. It's like an extra 3cm, not going to do any harm.
Very nice noise cancelling headphones - they come complete with a 1.2 metre cableI couldn't care less about a headphone jack. I've got a set of Sony WH1000XM3 headphones. For anyone that desperately needs one, there are adapters.
Well yeah, for things that don't support audio over Bluetooth. Which means they work on everything.Very nice noise cancelling headphones - they come complete with a 1.2 metre cable![]()
I haven't bothered turning aeroplane mode on any of my devices when on a plane in the last 10 years or so. It's really not necessary at all. I usually have at least a phone and a cellular iPad with me when I fly.A unnecessary frustration from not having it, particularly at airports and on flights.
I think it depends on a lot of factors, I definitely get audio lag using either my Bose SoundSport Free or my Bose QC35 IIs.
Sony's, you wouldn't notice it at all.
