PHP Explode to MySQL
28 Sep 2008
Britain
Google is not quite returning anything useful, perhaps I'm searching for the wrong thing.
Basically, I have a form. Username, Email and Password.
I have a MySQDB with id, username, firstname, lastname, password
When the user registers using a strict (corporate) email, I would like the PHP to handle exploding the email (delimiting at the .) to automagically populate the database firstname and lastname.
ie, User form shows:
Username: django x2
Email: [email protected]
Password: something
Then on submit, the DB will be populated with
Username: django x2
Firstname: django
Lastname: x2
Password: hashvalue
Alternatively, I guess it would be ok for a SQL timer job to come along and do that work (if Explode or a similar functions works in there).
TIA
daft question but why not save yourself the hassle and just put a first name/surname option on the registration form?
Having had a quick look at explode, it looks like you'd have to explode first on the @ symbol then use explode on the first element of the output array on the fullstop.
You'd then have a second array of 3 parts, firstname, fullstop, surname.
Explode will take your input string and output an array of strings. Then you need to address each string in the array that you want, something like this:
email_address = <value from form input>
exploded_array = explode(".", email_address);
first_name = exploded_array[0];
last_name = exploded_array[1];
I'd do it dynamically in the UI. When the user has entered an email (onBlur), if the name / surname boxes are blank, try to populate them with data from the email (given the expected format).
This then gives the option of whoever is entering the text to override it, incase their email isn't their 'go by' name. Eg Bob, instead of Robert, or Rik instead of Richard. Or if there are any exceptions (eg John.Smith2) to the standard rule.
Great if you want the last name to be smith@company :p
in a corporate environment emails do not necessarily match their names, example reasons:
- two people with the same name
- marriage
people can get touchy if you mess up their name, so best just give them a box to type it in.
and don't do first name + last name because asians.
Some interesting options.
To answer a few
1). There is no ambiguity on emails as fundamentally, the application will only ever return the firstname from the split string
2). That kind of answers the split(explode) at the period, because really, everything after the @ can be discarded
3). Our users are dumb, we'd get stupid Firstnames which would make identifying the user harder, so unless the form can dynamically fill in the firstname, but block it from being edited, then I would rather the user could not enter or choose a Firstname
$email = "[email protected]";
$firstname = explode(".", $email)[0];
$lastname = explode("@", explode(".", $email)[1])[0];
$username = $firstname . " " . $lastname;
Thanks, although the username is not their email address (without the domain) that's something different (confusing I know).
All that needs to happen is the DB fields need to populate a firstname and a lastname, even though the form doesn't explicitly ask for those. They are derived from the explode and inserted into the DB when the form is submitted.
