Anyone found a fix for HDR being completely broken with 5700 xt,s ?
You will be bottlenecked no mistake about it. You should get over 60fps but it'll be your .1% lows which will be affected most. On average it's roughly 85%-90% the performance of a 1080 Ti which was held back by my 4790k at timesAnyone running this with a 2500k?
I’ll be upgrading cpu in a few months but I can have a gpu now so just want to know if it bottlenecks at 1080p
Plan b it is then, just need to get my r9290 stable past 1100mhz. Wildlands is looking a bit console’y’You will be bottlenecked no mistake about it. You should get over 60fps but it'll be your .1% lows which will be affected most. On average it's roughly 85%-90% the performance of a 1080 Ti which was held back by my 4790k at times
Normal, zero rpm mode below 60c, mines not doing it though, I've messed sommot up lolIs it normal for the 3 fans on the red devil not to be spinning at times. They were still in Metro Exodus until I went in a menu or in game. The card is on OC mode. I read that they dont spin until the card hits 50c?
Anyone else notice this?
You got a budget?Cheers LeMson. Im loving the card and monitor at the mo, I need to bring the rest up to spec though.
Adding a pic of my Rig
Put me on the roll
You got a budget?
As much as it costs mate. Maybe £550 to £600. I've decided on Ryzen 3600. I was going to go Msi rickshaw max but can't see them in stock. Don't know about ram but I need 16gig. New psu and a ssd. Very happy with the red devil though.![]()
