Permabanned
- 9 Aug 2008
3a minimum or 2.5a if no USB devices pull more than 500mA combined. It's on the website![]()
Fantastic! Cheers for the info. There won't be any usb devices plugged in.
Can you get a 2.5amp plug though? I though the most i'd seen was 2.4amp otherwise you had to get a 3amp plug.
That splitter for example is only rated to supply 2.4 amps.
I also read that the fan shim runs at 0.6W, which i work out to be 0.12 amps. So depending on how power hungry your pi is, you may just about get the fan shim running on a 2.4amp plug.
.Morning all, have the pi4 4gb on way, looking for a good active fan cooling case, seen a few on the rainforest, one has quite good reviews, what cases are people using to keep this thing nice and cool? prefer one with a fan or one that keeps as cool as a fan.
News article from today about the release of the Rock Pi, similar size as the RPi but with an atom x5 in several RAM configurations:
https://hexus.net/tech/news/systems/134744-rock-pi-x-39-single-board-pc-intel-atom-x5-z8300
Can anyone recommend a decent power supply for a pi 3+ please that actually works as advertised? I had one that was working fine, but has since started giving me the yellow power symbol of doom. My pi is overclocked and quite often has a few controllers attached so I suppose I'm quite a heavy user. (Retro pi) Thank you all.
This. Dont cheap out you will only regret it.Use the official powersupply
Well you need a switch that supports POE surely this is down to your personal setup and what you need additional to the Pi. Otherwise just use a PoE adaptor.Can someone tell me what model of switch they are using to power their RPi4 please? (rackmount/fanless 8/12/16/24 port)
The Pi 4 4GB was available today for £36 inc VAT !
Sold out within an hour on ebay. Someone bought 250. I think the new revision 1.2 is due.
