- 2 Jan 2012
- UK.
They won't be priced like a high-end PC either.
In reality the gap between PC and console performance and visuals gets narrower with every generation, and it's only towards the end of each console generation that the age of the hardware and constraints in the original designs really start to show.
The Gap is huge, PS4 Protato and Xbone X (I have both btw) are seriously gimped by low end CPU. If you look at games it's not just frame rate that suffers on consoles. Shadows, details, textures are much lower and upscaled to 4K so they can use the keyword '4K' graphics and people that are none the wiser lap it up. Thinking they have parity with PC.
I mean I jumped in with both last gen consoles and wish I saved the money for PC.
Am def skipping the next gen of consoles as PC will be ahead even at launch with the gap widening even further as time passes.
For those happy with consoles it's great. This is just my opinion, Each to their own and all that. My money will spent on GOG (No drm ftw) and not on £499 console and £59.99 games. Would rather spend £499 on a next gen GPU when I can just drop that into my PC I already have anyway if you get what I mean.
That isn't true at all though. You literally only have to step back one generation to the Xbox 360 to find a console that wiped the floor with high end PCs at the time of its launch. It had a superior GPU to anything available for PCs at the time, plus a triple-core, six-thread CPU running at 3.2GHz at a time when the best you could do in a PC was a dual-core Athlon 64 X2. Of course, that generation ended up going on so long that the Xbox 360 and PS3 were massively behind PCs by the time they were put out to pasture, but at least they can say that they were once competitive. The Xbox One and PS4 weren't even close at launch, unless you're failing to take into account the 20-30fps vs 60fps+ gap.
Well said, this guy gets it ^^
In the past console at launch would be ahead of PC. PS4 and Xbone bucked this trend and were weak at launch. The mid cycle upgrades basically added at 4K upscaler and use same weak CPU.
The next gen consoles look even weaker in comparison to already existing PC architecture. Doesn't bode well for the next few years.
With consoles basically becoming a PC with an mid end APU, but forcing the buyer into a walled garden pay system, and having to pay to play online..
Why not just buy an actual PC with DGPU and save a ton on the games, and do way more with a PC. Just a thought.
