Pic: Your desk...RIGHT NOW
26 Sep 2013
West End, Southampton
21 Oct 2011
ST4
Here is a cool little setup for those lacking space like me, or on a budget. Comes in at £47 for the whole desk plus £25 for the mega mat.
Linmmon table top £15 - http://www.ikea.com/gb/en/products/desks/table-tops-legs/linnmon-table-top-black-brown-art-00251343/
Adils legs x4 £10 - http://www.ikea.com/gb/en/products/desks/table-tops-legs/adils-leg-black-art-70217973/
Lack wall shelf £10 - http://www.ikea.com/gb/en/products/...l-shelves/lack-wall-shelf-black-art-10011017/
Capita legs £10 - http://www.ikea.com/gb/en/products/...nets/capita-leg-stainless-steel-art-10267895/
OcUK megamat £25 - https://www.overclockers.co.uk/ocuk...-elite-tactical-gaming-surface-gs-000-og.html
Now there is a slight dip in the middle of the shelf but I did have a very heavy older monitor on there till recently. :D
Was after a cheapo replacement for my current desk. Think I'll grab this combo, but with the shorter 8cm legs for the shelf. :)
Dup
Dup
10 Mar 2006
East Lancs
Needs the signum cable tidy, makes a good difference with some vecro cable ties. I have a similar desk but in white, not keen on a raised shelf though, going to get a monitor arm eventually but these Ikea tips end up bowing a bit so might need a new solid desk too when the time comes.
Man of Honour
29 Jun 2004
Oxfordshire
Mouse slowly wearing the desk surface away - you monster!
Ha :D I regret not coating it when I bought it, will definitely do that with the next one. I wouldn't mind getting a mousepad, but I can't find one I like that doesn't show dust/dirt easily as I want it to be a darker colour to contrast the wood. Did have an OcUK one but they are terrible for showing dust
20 May 2011
Aberdeen, Scotland
That's kind of why I asked @LiE what he was using - looks like some kind of thin leather pad that would probably work brilliantly and be easy to clean.
Too bad he ain't replying. :(
Don
23 Oct 2005
North Yorkshire
Started using my iPad Pro’s as extra screens, works out quite well, more screens the better while trying to learn React and VueJS :o
Are you using software so your iPad screen is another display to drag things onto? I'm just trialling spacedesk but it's a big laggy and the resolution is a bit rubbish. Has anyone some recommendations for software like this?
The lag doesn't concern me as I'm only having Spotify running on there but it would be nice if the resolution could alter from 1024x768.
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Man of Honour
29 Jun 2004
Oxfordshire
I was using side car with the new macOS beta which worked really well but took the beta off as I had a few issues with other pieces of software. So for now it’s not connected at all until the GM comes out
20 May 2011
Aberdeen, Scotland
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Recently added the following hardware to my setup.
Razer Core X
Sapphire Nitro+ 5700 XT
Huawei VR 2 cable
You can see the Razer Core X under the desk, I have it in a vertical orientation to allow me to use the 0.5m passive TB3 cable to the Mac mini above. I did have it on my desk but I prefer to have it under the desk as it's quieter. The Huawei VR 2 cable allows me to connect the Display Port out on the 5700 XT, combine it with USB-A and output to USB-C to drive my 23.7" LG UltraFine 4K monitor.
Windows has been installed in boot camp allowing me to play games on there as well using the 5700 XT. This is pretty much my perfect setup.
Caporegime
13 May 2003
Warwickshire
Mainly a HiFi / browsing station. Just got some Monitor Audio Bronze 2s to replace the Wharfedale Diamond 10.1s that were in there before. Also have a BK XLS200 10" sub on the way. Speakers are driven by a NAD D3020 (great stereo amp, tucked away on top of the tower). Screen is a Philips 40" VA job.
Desk top is solid oak.
