The ZombieLoad attack allows
stealing sensitive data and keys while the computer accesses them.
While programs normally only see their own data, a malicious program can exploit the fill buffers to
get hold of secrets currently processed by other running programs. These secrets can be user-level secrets, such as
browser history,
website content,
user keys, and
passwords, or system-level secrets, such as
disk encryption keys.
The attack does not only work on
personal computers but can also be exploited in the
cloud.
https://zombieloadattack.com/
ZombieLoad in Action  CVE-2018-12130
In our demo, we show how an attacker can monitor the websites the victim is visiting despite using the privacy-protecting Tor browser in a virtual machine.
https://www.pcgamesn.com/intel/zomb...y-patch-hyperthreading-mitigation-performance
“We conclude that disabling hyperthreading, in addition to flushing several microarchitectural states during context switches, is the only possible workaround to prevent this extremely powerful attack,” a research paper describing the Zombieload flaw, authored by researchers at Graz University of Technology, Cyberus Technology, Worcester Polytechnic Institute, and KU Leuven, says.
https://mdsattacks.com/
RIDL and Fallout: MDS attacks  CVE-2018-12126, CVE-2018-12127, CVE-2019-11091
The RIDL and Fallout speculative execution attacks allow attackers to leak private data across arbitrary security boundaries on a victim system, for instance compromising data held in the cloud or leaking your data to malicious websites. Our attacks leak data by exploiting the 4 newly disclosed Microarchitectural Data Sampling (or MDS) side-channel vulnerabilities in Intel CPUs. Unlike existing attacks, our attacks can leak arbitrary in-flight data from CPU-internal buffers (Line Fill Buffers, Load Ports, Store Buffers), including data never stored in CPU caches. We show that existing defenses against speculative execution attacks are inadequate, and in some cases actually make things worse. Attackers can use our attacks to leak sensitive data despite mitigations, due to vulnerabilities deep inside Intel CPUs.
RIDL
RIDL (Rogue In-Flight Data Load) shows attackers can exploit MDS vulnerabilities to mount practical attacks and leak sensitive data in real-world settings. By analyzing the impact on the CPU pipeline, we developed a variety of practical exploits leaking in-flight data from different internal CPU buffers (such as Line-Fill Buffers and Load Ports), used by the CPU while loading or storing data from memory.
We show that attackers who can run unprivileged code on machines with recent Intel CPUs - whether using shared cloud computing resources, or using JavaScript on a malicious website or advertisement - can steal data from other programs running on the same machine, across any security boundary: other applications, the operating system kernel, other VMs (e.g., in the cloud), or even secure (SGX) enclaves.
Fallout
Fallout demonstrates that attackers can leak data from Store Buffers, which are used every time a CPU pipeline needs to store any data. Making things worse, an unprivileged attacker can then later pick which data they leak from the CPU's Store Buffer.
We show that Fallout can be used to break Kernel Address Space Layout Randomization (KASLR), as well as to leak sensitive data written to memory by the operating system kernel.
Ironically, the recent hardware countermeasures introduced by Intel in recent Coffee Lake Refresh i9 CPUs to prevent Meltdown make them more vulnerable to Fallout, compared to older generation hardware.
https://portal.msrc.microsoft.com/en-US/security-guidance/advisory/ADV190013
These vulnerabilities are known as:
- CVE-2018-12126 - Microarchitectural Store Buffer Data Sampling (MSBDS) 
- CVE-2018-12130 - Microarchitectural Fill Buffer Data Sampling (MFBDS)
- CVE-2018-12127 - Microarchitectural Load Port Data Sampling (MLPDS)
- CVE-2019-11091 - Microarchitectural Data Sampling Uncacheable Memory (MDSUM)
To be fully protected, customers may also need to disable Hyper-Threading (also known as Simultaneous Multi Threading (SMT)).
Potential performance impacts
Specific performance impact varies by hardware generation and implementation by the chip manufacturer. For most consumer devices, impact on performance may not be noticeable. Some customers may have to disable Hyper-Threading (SMT) to fully address the risk from MDS vulnerabilities. In testing Microsoft has seen some performance impact with these mitigations, in particular when hyperthreading is disabled. Microsoft values the security of its software and services and has made the decision to implement certain mitigation strategies in an effort to better secure our products. In some cases, mitigations are not enabled by default to allow users and administrators to evaluate the performance impact and risk exposure before deciding to enable the mitigations. We continue to work with hardware vendors to improve performance while maintaining a high level of security.
Mitigation strategies
Intel has provided CPU microcode updates, and recommendations for mitigation strategies for operating system (and hypervisor) software. See Intel's
Security Advisory for more details. We recommend you install the software updates provided by your operating system and/or hypervisor vendor.
In addition, we recommend disabling Simultaneous Multi-Threading (SMT), also known as Intel® Hyper-Threading Technology, which significantly reduces the impact of MDS-based attacks without the cost of more complex mitigations. Note that you might still be vulnerable despite disabling SMT, as MDS does not strictly rely on the presence of SMT.
