Alright so the setup is a 3700x stock with a Aorus Elite x570 and some Patriot Viper 3600mhz CL17 ram, it's not on the QVL but the Ryzen RAM calculator says it should run at this speed based on them being Hynix CJR die. I haven't tried that much with them, tried increasing DRAM volts to 1.40v however it just seemed to give the memory management blue screen even faster than when it was at 1.35v, the SOC voltage is on auto so sits around 1.08v, one thing that got me thinking is maybe the Infinity Fabric is the issue? Once I overclock the RAM maybe the motherboard has clocked the IF to 1800mhz and because SOC volts are too low I'm getting issues? Without going into too much detail all I'd like is the IF and RAM to be 1:1 with decent timings (XMP would be great).
https://docs.wixstatic.com/ugd/20c50...c4040697bf.pdf
Data sheet to the kit I have.
I'll have another play with it but from what is happening wouldn't mind getting some advice, my BIOS gives the choice of having an offset on the SOC, I'm probably best setting 1.2v and having no offset right? Maybe I just got a turd of a memory controller and it needs some juice to get it going.
