- 28 Nov 2018
- Monstrocity
yes this is right, the skins pack is a separate key, thats how my keys from cdkeys came.
Same here.
I think your frustration should be directed at the developer instead. Besides borderlands 3 on consoles is a ****show right now anyway and way worse than on pc(which is odd considering its usually the otherway around).Those are shockingly low numbers across the board for Borderlands art style. Not even 100fps for a £1500 GPU at 1440 ultra settings. Roll on next gen consoles, I'm done with overpriced PC hardware and gaming these days.
Are you guys enjoying the game so far then and who are you playing as? I have gone with Zane for my solo character and Moze for co-op.
Upgrade your SDUs
I've updated a few of them but the guns I've got seem to be chewing through the ammo at a mad rate.
I decided long ago to wait the 6 months for the steam release.
Not gonna lie... Really struggling, might fold.
I love getting caught up in the hype and mystery of new releases, I'm not sure the benefit of sticking to my principles is worth waiting 6 months anymore....
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
I'll decide tomorrow...
Quick one line summery from those playing now if you would be so kind?
BL2 but bigger and better?
Stay strong!
Thanks for the support bro. I'll try my best!
You wouldnt be the first to do a 180 on the decision not to buy from Epic, some in the thread already have and I would wager you wont be the last.
As someone who has had no performance issues and no resolution issues, BL2 but bigger and better does generally sum up my thoughts on the game.
Dont cut your nose off to spite your face !
Borderlands 2 but 10x better the guns are the best bit of this game they are all different
I caved, I regret that I did. Not that impressed really.
Dont forget, Epic have the same refund policy as Steam, so you could always buy it, give it the <2 hours and refund it if it doesnt meet your requirements![]()
Its tough... 6 months is a long time! Glad to hear you have no performance issues. Is it cutting my nose off to spit my face though to stick to my principles?
