My R5 3600 idles at around 29C. Running Prime95 for a few minutes and peak temperate is 55C (just under 50C form most of the tests). OK, it's a couple of cores down, but I wouldn't have thought a couple of extra cores at idle would increase idle temp by much. I can't see why a 3700X would idle at much above 30C with a decent cooler.
Tell a lie. I've just run Prime95 for half an hour. Peak temp is 76C with core voltage set at 1.35v. Stopped the test and a minute later temp is 30C.
		 , but rather uncomfortably hot to hold the finger on them.
