I got this case and done a new build recently for a family member.
Cons:
-Its very light, thin plastic type material well kind of hard to describe its got some strength to it but its not made from steel or solid material.
-its like those cheap light £19.99 china made ATX cases you find at the computer markets the ones you can pick up with 2 fingers either end.
-USB 3.0 ports only on front, no 3.1 or USB 3.1 C port, feels like they cut corners but its no different to others around.
-cramped on the top side, I had to remove entire motherboard after build since I could not get 4 pin cpu wire in no space.(just needed inch more space,
if they made the top part totally removable could have solved all issues and they already done it half way with magnetic covers.
-also cramped on the back side panel, even an award winning £180 Titanium seasonic ultra prime power supply still use ultra thick 24 pin cables and the side panel needed a far bit of push and this was after spending half an entire day cable tieing and hiding and flattening all the cables.
-the plastic material of the case and noise dampening material not really doing too much, I think the panels are just too thin and plastic.
Pros:
-One of the best looking mid range cases I think I have used if not the best.
-Excellent design, I reckon bulky hdd cages belong in the past the futures m2 and ssd.
-half the cable tieing and management was already pre-done on the back side of the case, this speeded up the work more and also appreciated the
pre screwed ATX motherboard screws in place although there was one pre built (one recent reviewer said he struggled to get his motherboard to lineup
correctly id bet he missed inserting that pre built atx bolt on into the mobo hole since its so small and easy to miss)
-140mm fans are decent and shift decent air and 3 pin so no risk of the PWM coil whine, id say there a tad noisy still but quiet just not silent.
I have only tried it for a few days but I miss the solid steel panels from coolermaster and others it really can aid in silence, If my relative finds it bit too noisy
I may opt for some 7volt fan noise reducer cables. Still no case is perfect and its still probably the best looking and easiest to build for I have had.
