RDNA2 is 2021 and "select lighting effects"![]()
And maybe by that time ray tracing will be worthwhile.
right now the performance hit
HahahahahaOr on planet earth (a place you might want to visit once in a while) the designs for the 5 series were already done and there was no way they could implement ray tracing support until further down the line on another product.
You make all this sound so simple, most of your posts come off like amd should be able to pull titan rtx killers out of their ass on a whim. If it was so simple I'm pretty sure they would have done it by now.
nvidia's RTX series are already a year-old. Their development started several years prior to that. Microsoft knew.... Don't tell me that AMD didn't know that nvidia was working on RTX.
Hardware ray-tracing acceleration will always hit badly the framerate - there is no workaround.
Response to:
I think AMD could quite easily produce an RTX Titan killer now they have 7nm available.
The RTX Titan has two disadvantages.
1. It is on 12nm.
2. It is saddled with all the extra silicon needed for Ray Tracing and DLSS.
If AMD produce a high end card on 7nm without Ray Tracing it will be fast.
Having said that it would be a pointless exercise as AMD are better off keeping their resources where they are now to maximise income.
They have 7nm available but we've no idea how long it will be before a card of that type would materialise. The way 4k8k talks amd should be able to magically pull cards and cpu's with unrivaled performance out of their asses in 5 minutes
Yeah OK. Unless Sony and Microsoft are pushing their new consoles back to 2021, RDNA 2 is next year.RDNA2 is 2021 and "select lighting effects"![]()
The RD is a nice card indeed. And it too has a 10-1 power phase if memory serves me correctly. However, I've not seen the RD do 930MHz memory while undervolting. UV on the Tiachi only seem to reduce FPS between 1-3 (with 930Mhz on memory) while bring the power/heat inline with the Nitro.Tiachi is awful on temps and fan noise. red devil seems the best buy.
@EastCoastHandle don't use techpowerup as reference
Everyone has recorded 34db on idle for the the 2070S and they show it at 33db on load.
It's very easy to advise that but would you suggest an alternative with similar large database and structure of "reviews" and performance comparisons since the oldest graphics cards?
An alternative with similar to GPU-Z app for recording the GPUs specifications?
