How to clean this shower?
21 Nov 2008
It looks as if the chrome has discoloured but it seems to be within the frame.
Is there any way to clean this?
Feel sorry for people that find life this complicated, remove the panel if it's worrying you that much, and give a good clean out
I'll give it a go. The problem is getting it in there. It's kind of closed but clearly not enough to not allow water in.
i'd cheap bleach from aldi. put it in a spray bottle. dilute with maybe 25% water to make it more runny.
then just spray it everywhere. repeat this spraying process once every hour for 4-6 hours. if it's not gone by then buy a new shower.
you do know it's just bleach right? with some foamy stuff so it clings better
they like to call it this though
https://en.wikipedia.org/wiki/Sodium_hypochlorite
so it sounds fancy.
it's just bleach. which is like 45p for 2 litres in aldi.
I wonder if it's the foamy stuff then, as I find it works so much better than bleach.
Maybe that's because I spent more. My brain is telling me it was a good purchase.
