- 25 Jun 2006
Absolutely loving this game. 3 days playtime already on Moze.
Yes they do, you dont need to remain in the same skill tree. Just look at the skill icons under your xp level to see what's triggered
I'll post later as I play this on ps4pro at the moment, waiting on Steam release. At work currently. Orange tree is the key tree for zane as you get massive bonuses to damage when used with the blue tree....forget the green tree.
I think I'm getting something like 80% gun damage alone just by a few skills in either tree, plus movement, reload and crits enable you to be a walking straffing killing machine. Theres also a skill I use which gives you endless use of the sentinel if timed correctly, it's the missile salvo....use when the sentinel is running out, if you get a kill it recharges to 100% again.
From memory the key ones from blue tree are Violent speed, violent momentum, cool hand, cold bore (for weapon swap speed) then I think it's bad dose and almighty ordnance for the 2 augments.
Key in orange is anything that gives you crits and higher dps, think its synchronicity, magazine size one can't remember name, Donny Brook, for the augs I'll need to double check later think one is shield recharge
I'm really liking this game, enjoying Fl4k.
Even more it plays quite well on my 2500k and 980ti, although I do have a 1080p GSync display which may help.
The latest patch has helped performance a LOT for me
I think I'm around level 29 - the only negative for me is that I want to run through other characters and try them out but I REALLY don't want to go through the story again to do it.
I would love a Diablo 3 type scenario when once the campaign has been completed with one character then you can skip it with others and just level up doing less tedious/quicker tasks![]()
I don't think it matters anyway, you will be swimming in cash later in the game.
If anyone's looking for a good boss farm on Mayhem difficulties, get on General Traunt. His drop rate for legendry's is superb. Averaging 7 or 8 every 10 runs, often times with double drops. Doens't appear to have a dedicated drop so he's great for farming world drops.
Bit of a chunky shield but if you can get something like a 'Storm Front' or a 'Hex' then you're laughing.
Tis alarming how easy it is to break the game at the moment. If you pick you skills right with Moze and somehow get lucky enough to grab a 'Flakker' all the bosses become a joke.
Killed that thing yesterday for the first time. Took me a good 15 minutes, maybe more. It was a fun fight!Better than the Graveward farm or?
