Errornous =SUM result in G Sheets
27 Dec 2005
Bristol
I'm getting an incorrect result when using =SUM in Google Sheets. Any idea why?
It's really basic. The formula is =SUM((C2:C63)/62), so it's just an average with the C column simply being numbers. However the output of the formula is 4.84% but the correct answer is 4.629032% (nowhere near the result even if rounded up).
The column totals correctly as 287 when using =SUM(C2:C63), and using =SUM([that cell]/62) works as well.
I'm stumped, and it's making me doubt/check all the other formulas which isn't particularly productive.
28 Oct 2006
Sufferlandria
You're not using the correct syntax. SUM adds the values of the range between the cells in the brackets after it. You use it like SUM(cell1:cell2)
If you want to use the result of that in another calculation, you dont change whats inside it's brackets, you add the calculation around it.
=SUM(C2:C63)/62
or
=(SUM(C2:C63))/6
22 Jun 2018
Doon the watah ... Scotland
Yeah, touch is right. I suspect the formula you're using is dividing each cell by 62 individually, then summing the results.
But why would that give a different result ? If all cells are individually divided by 62 ... they surely should give the same value as all added, then divided by 62. For example, dividing by 10:
Code:
(A/10) + (B/10) + (C/10)  should be the same as  (A+B+C)/10
(2/10) + (3/10) + (2/10) = (2+3+2)/10
0.2+0.3+0.2 = 7/10
0.7 = 0.7
Whether the structure of the formala typed is easiest or not ... the result should be the same ? As so the OP is correct in his complaint ?
The only thing I can think of that the cells properties are being restricted to 2 decimal places or something similar, which when each cell division is calculated, the rounding to 2 decimal points is combining to create the errors.
19 Jul 2011
Its not dividing all the cells in that range by 62 though.
It's taking the range and performing a divide against it and then trying to sum that, which is syntactially bad.
It might be mathematically logical in your head, but you can bet the programmer of that function never coded it to work that way.
The function is expecting an input of a certain format, and the user is randomly choosing to divide it by 62 before asking the program to call that function.
