- 21 Jul 2005
- Officially least sunny location -Ronskistats
Stop it just because your on a 5700XT now!![]()
The dx9 support means little though
What dx9 game can't play with native 4k etc?. RIS may enhance the IQ but its moot with this level of game.
I'd be excited for RIS if it was DX11.
Fair point. It is peculiar that DX11 sees no support for RIS, there's obviously something in that API that doesn't play nicely with it.
Getting crashes on two point hospital using Adrenalin 2019 Edition 19.9.2 for my sapphire 5700.
What's the best way of reporting this to amd?
Monitor resolution is 3840x2160. Game resolution is set to 1920x1080.
Radeon Settings -> Display -> Scaling Mode is set to Full panel.
The issue is that when the game is launched, it occupies the left top quadrant of the screen and there is no way, I haven't found a way to make it full screen.
What's the problem with AMD Radeon Settings?
I've had this as well but I can't remember which game it happened with now, It may of been Bowl-o-rama.
Pressing alt and enter used to fix this for me. The games i used to have problems with this happened on both Nvidia and AMD so was likely a game problem back then. It's worth a go though as it's never failed me yet when it happens.
It would be great if they can do it though. How many great games like The Witcher 3 or GTA 5 would benefit? DX11 stayed with us a long time, there are a lot of good games that were made while it was around.
Had some crashes with these new drivers just browsing on chrome. Thought it was cpu oc but its been fine and gpu drivers were updated recently so its probably those im thinking.
If i do, scrolling is worse, so no thats not a option.
Never any issues with scrolling ob chrome I disable hardware acceleration.
In my system, scrolling is also not ok when HA is disabled.
Maybe someparts of your configuration are more powerful and take care for smooth scrolling.......
Support For
AMD Radeon™ RX 5500 desktop graphics products
AMD Radeon™ RX 5500M mobile graphics products
GRID™
Fixed Issues
Borderlands™3 may experience an application crash or hang when running DirectX®12 API.
Borderlands™3 may experience lighting corruption when running DirectX®12 API.
Display artifacts may be experienced on some 75hz display configurations on Radeon RX 5700 series graphics system configurations.
Radeon FreeSync™2 capable displays may fail to enable HDR when HDR is enabled via Windows® OS on Radeon RX 5700 series graphics products system configurations.
Some displays may intermittently flash black when Radeon FreeSync is enabled and the system is at idle or on desktop.
Known Issues
Radeon RX 5700 series graphics products may experience display loss when resuming from sleep or hibernate when multiple displays are connected.
Toggling HDR may cause system instability during gaming when Radeon ReLive is enabled.
Call of Duty®: Black Ops 4 may experience stutter on some system configurations.
Open Broadcasting Software™ may experience frame drops or stutter when using AMF encoding on some system configurations.
HDMI® overscan and underscan options may be missing from Radeon Settings on AMD Radeon VII system configurations when the primary display is set to 60hz.
Stutter may be experienced when Radeon FreeSync is enabled on 240hz refresh displays with Radeon RX 5700 series graphics products.
AMD Radeon VII may experience elevated memory clocks at idle or on desktop.
Important Notes
AMD Ryzen™ Mobile Processors with Radeon™ Vega Graphics FAQ for Radeon Software Adrenalin 2019 Edition can be found here.
