- 11 Mar 2016
ok details on my setup
Ryzen 3900X
Custom Water cooled loop (2 x 360mm rads)
Asus ROG Crosshair VIII Formula X570 Motherboard (ROG CROSSHAIR VIII FORMULA BIOS 1001)
G.SKILL Trident Z Neo (For AMD Ryzen) Series 16GB Model F4-3600C14D-16GTZN
I have installed the latest AMD chipset drivers and ini files for all devices
I basically a newbie when it comes to Ryzen this is my first AMD system. I had intel before which i just changed the multiplier to a value and it was kinda it for OC'ing.
My CPU temp at idle is sitting around 35-50c jumping around.
My R20 cinebench is around 6800 (-/+ 30)
Windows task manager shows my CPU to be in the range of 4.1-4.3Ghz
Voltages at idle are 1.45 on around 80% of all cores
I have attached some screenshots below i basically have no idea when it comes to Ryzen and im learning fast.
I have heard that Motherbaords basically have crap BIOS's and voltage needs to be hardset in the BIOS at around 1.3/1.35 max untill a fix is produced.
Ive watched a ton of videos on youtube around OC'ing ryzen but they all talk to fast or if you have previous nohow.
I guess the main questions are:
Ryzen 3900X
- is 1.4-1.5v normal and to be exepcted either at idle or boost?
- how the hell do you use Ryzen master
- what values if any should be an MUST in the BIOS to change
- what Ghz should i really expect
