Why? Do you need an upgrade? unless you need 12 cores i would say don't bother, if your 3930K is still serving you well, stick with it.Someone convince me to move from the rig in my signature to a 3900X...
That's not what I wanted to hear damn it!Why? Do you need an upgrade? unless you need 12 cores i would say don't bother, if your 3930K is still serving you well, stick with it.
I'm looking to do a lot of virtualisation and with Overclockers finance offering buy now pay over 12 months (before crazy interest kicks in) it seems a no brainer. Would pay a grand over a year, nothing really. I expect the processor to last me just as long as my 3930k has too.
well its a good chip, i mean, i don't know what else to tell you, just do it
That's not what I wanted to hear damn it!![]()
What’s the matter with you? You’re a madman ffs, your CPU is embarrassing.Someone convince me to move from the rig in my signature to a 3900X...
I’m waiting to upgrade my 2700x to a 3900x but I’ll give them 6 months to actually make some, sort the bugs out, sort the clockspeed issues out and sort the pricing out!Someone convince me to move from the rig in my signature to a 3900X...
yeah I de-clocked my ram which has improved things.
Ryzen 3000 is a bit finicky with RAM, particularly on earlier BIOS's. Each BIOS has expanded RAM compatibility. Try the SoC at 1.1v
Make sure you use DRAM calculator and select the correct CPU, chipset, ram & ranks. The values would be different between Zen 1, Zen+ and Zen2.Ryzen 3000 is a bit finicky with RAM, particularly on earlier BIOS's. Each BIOS has expanded RAM compatibility. Try the SoC at 1.1v
Also do you use at least 7B77v1B bios? It improves memory compatibility.
