- 28 Sep 2018
A few points on the 9900k that might need updating:
- A 5ghz 9900k gets ~12,800 in timespy. Maybe that's a stock score?
- You can run 5ghz without an AVX offset. Most of us do. You can use OCCT and x264 stress tests to test avx stability
- Your cooler needs to able to handle out 230w/150a *On a 9900k* to be effective for stress loads. However, you'll not see those loads in gaming or normal workload. Doing a ton of rendering being the only exception thus the x264 stress test
