The Radeon RX 5700 XT Owners Thread.
17 Jan 2017
Having installed a Pulse 5700xt and then MSI afterburner I'm getting GPU temp 1 60/70 GPU temp 2 80/90.
GPU 2 temp would mean a 2nd GPU but GPU trmp 2 is a second temp for GPU or I'm I missing something?
Just realized, this should be in the owners thread and I can't move it.
Merged by Moderator
Caporegime
12 Jul 2007
United Kingdom
My Nitro+ hits 2045 at 1.182 stock
Is that the setting in WattMan?
My 5700 XT AE will do 2063Mhz stock at 1.138mv which in game is around 2000-2025Mhz. The only problem is on a super stressful game like Witcher 3 at 3440x maxed, you require at least 55% fan speed to stop from throttling.
In other games though you can get away with 50% ish.
I am going to try the washer mod to try and bring the temps down a little.
30 Sep 2011
Over the hills and.......
He means the pcb/vrm is slightly worse than reference. What that actually means in reality is very little.
Thanks,
Shouldn’t have posted that, it all made sense when I watched the red devil analysis.
Anyway no nitro for me, not at 310mm length. Looking at the red Devil now no dimensions listed on ocuk
Edit: red Devil is 300mm and both cards are 130mm wide, means I have to cut up my front rad and move my res. I could swap the front and top rad over but then I lose the rear rad and still have nowhere to put the red. If I buy a bigger case it’ll mean I might have to re assess my razen 3000 upgrade :(
26 Aug 2010
8 Jun 2018
Yeah I sw the thread earlier.. he has updated it since with the video. I can replicate the wattman slider behaviour but my boost holds fine in the only game installed that he mentions (overwatch).
I can also confirm this. This is a major issue that might explain why I am having issues.
@Panos did you watch that video yet in that reddit post?
Here is my post about the problems I'm having with the Nitro
https://forums.overclockers.co.uk/posts/33059476
Has anyone got Enhanced Sync on?? I've free sync on and don't know whether to have image sharpening on, anyone with advice be greatly appreciated. Also has any experience a micro stutter?
I don't use it myself as I want raw performance. Do you actually see tearing? If so freesync should be all you need. And turn on Image Sharpening (no performance hit). I notice it in game right away.
19 Jan 2019
Co. Down, N.Ireland
@Panos did you watch that video yet?
Cheers mate will give it ago
