- 9 Dec 2015
Depends your budget.
I'm either going to buy tomahawk max or wait for the carbon AC version of b550
I've a tomahawk max which seems to do what it should in regards boosts, seems stable, runs cool, and that under stock.
Still playing about with it, but frankly, as I am not planning to push that machine to do much, i won't be spending long at it, all seems to do what it should do, including the boosts.
If you are buying 3600 3600x or low end, I'd have no hesitation regarding the max, as long as you only need 1 m2 slot, and don't need pcei4, which the B550 probably won't have anyway.
If you are planning to slot a future processor inside, then consider wait.
Aye that is the thing, my wife's machine was so old I cba waiting, and it isn't going anywhere, there is a usb c on the back, and a usb3..2 as well as 2*3.1 on the back, so i am happy enough from a remote connection POV in future.
Sound isn't a big issue with her, there are various speaker connections, but bar a simple 2.1 I wasn't adding anything more. So can't comment on sound.
I think the b550 are not far away tbh.
This is a bit of a noob question but the latency you see on people's aida64 tests, is tha cpu,RAM or motherboard dependent or come into it at all?
Ok thanks. I'm trying to learn how to do it on my own without Ryzen calculator so was just curious.Mainly RAM speed and timing dependent, the higher the CPU clock speed can decrease latency as well.
That is rather interesting, in half the benchmarks they jumped the 9900K.
I assume these games are AMD friendly?
Or has there been that much of a change with maturation of the platform?
If you do not want PCIe 4.0 get a B450 or B550 board. Tomahawk Max is a great board already.
It works nicely with 3900X and it would with 3950X.
Keep away from Carbon. No other reason the X570 carbon is a pile of poo, already replaced by the Hybrid in just 2 months.
Tomahawk Max is from MSI.I thought the B450 carbon was regarded as one of the best?
8 core CCX per CCD with new better I/O, plus 20 million more transistors, plus 7nm+ process.Anyone think overall gaming performance gonna improve much with Zen 3? Wonder if minimums will get up to Intel level or so where they are behind a bit.
