 - 31 Mar 2016
 - Moonbase Alpha
I say G-Sync is dead. Freesync won![]()
No. If 'G-sync' can smother out 'Freesync' the mindshare of g-sync has very much won.
But G-Sync is Freesync now. G-Sync as you know it is dead, Freesync won.No. If 'G-sync' can smother out 'Freesync' the mindshare of g-sync has very much won.
Actually, how long before the misinformed start believing that AMD always did gsync?How long till an AMD based card is advertised as being G-sync compatable.
Surprised no one has mentioned this...
Nvidia are market leaders in GPU's in fact they own around 70% of the market, as opposed to AMD at 30%.
So it makes sense for the monitor manufacturers to label them as Nvidia certified as opposed to AMD certified. This way they appeal to a much larger audience, thus helping them increase sales..
I think the outcry is due to manufacturers widely dropping the Freesync branding completely. It's highly suspicious that so many have. They are using Freesync, but labelling it GSync compatible. Then many of them removing Freesync brandig. A more supisius person than me would think that maybe the terms set by nVidia was that they had to drop Freesync branding if they wanted to use the GSync name ¬_¬Surprised no one has mentioned this...
It more than likely is or they would use both badges.I think the outcry is due to manufacturers widely dropping the Freesync branding completely. It's highly suspicious that so many have. They are using Freesync, but labelling it GSync compatible. Then many of them removing Freesync brandig. A more supisius person than me would think that maybe the terms set by nVidia was that they had to drop Freesync branding if they wanted to use the GSync name ¬_¬
Just looked up two of the monitors mentioned still showing as freesync in the description.
Nvidia is a much superior brand than AMD, its like comparing a Mercedes to a Vauxhall.
I doubt AMD cares that much as they are dominating NV in the far larger console market, and will have their GPU in the Scarlet and PS5 , and their Ryzen chips are have replaced Intel as the go-to CPU for laptops.
NV just looks like a bitter old sad sack.
The difference between adaptive sync and Freesync is that
Freesync was founded on the adaptive sync standard. However, requires specific (better) scaler hardware.
I still can't find info if that scaler hardware is specific to Freesync or something else. But the difference is in the scalar hardware only found in Freesync monitors.
Wow I must have missed the thread about the new AMD giveaway, the one with a free pair of rose tinted glasses with every AMD product.![]()
To be fair that is the objective. IE: AMD never had their own way...
I remember AMD creating the 'freesync' brand and laughing at nVidia. You're not laughing now.. are you.
Definitely, always more expensive but with with poorer image quality.
