Are you also one of those people that are always ill?Then again, this iPhone I'm using I've found 2 annoying faults already today, so I am actually starting to wonder if I am the problem and I simply expect too much from these things. I am unsure as everyone I know just tells me I'm unlucky with everything I buy (was the same with cars, always seemed to run into every documented fault going), but then I wonder if I just notice things that other people just don't notice or care about....
Yeah it was him. he said if you look away it drops down. Edit: https://youtu.be/085_hlIcLu8?t=147 (2.30ish)THAT makes more sense but I definitely saw the review where the guy said it was when you were looking at it - pretty sure it was mrwhostheboss or whatever he's called.
I was just wondering the same thing.How will verifying purchases work without finger print reader? How do I login to apps? Buy things from play store? Purchase above the £30 contact less amount?
Man I've nearly bought a 4XL 4 times this afternoon so far. I need to go to a shop and see them in the flesh.....
