ASROCK X570 TAICHI - THE RYZEN 3000 MOTHERBOARD GIBBO & 8 PACK RECOMMENDS
If you get crackling sound from time to time, is the latest realtek drivers. Go to Device Manager. Right click the realtek sound, select uninstall and tick to delete the driver.
Right click the root item of the Device Manager and select to Scan devices. It will install the default Windows Realtek driver having no issues.
Btw this issue exists on all Asrock boards, even Intel Z series.
Has anyone managed to bclk overclock?
Even 1mhz stopped my SATA drive from functioning. I forgot I'd adjusted it and spent days troubleshooting until I realised.
Pretty sure I read somewhere that you don't OC BCLK particularly with NVME drives, but an SSD via SATA I haven't seen as a reason not to.
DO NOT USE THE BETA 2.30 BIOS FOUND ON REDDIT.
If you do not want to spend the next 1 hour of your life trying to roll back to 2.11
The real question should be is what on earth are you doing trusting a bios file taken from reddit :eek:
True was beta bios wanted to give it a spin. :)
Hadn't tried previous beta bios' but this one seems promising. But well :) mistakes
2.11 also appears to have been removed. Not that I'm noticing any issues, that is slightly concerning.
I had issues with RAM overclocking, my audio would start crackling when the RAM was overclocked to an overclocked that works fine on 2.10. So I guess there were some issues.
Yep. I concur to this with the 2.11
I see the beata BIOS's with AGESA 1004 are now available under the BETA sections for each board @ ASRock. Anyone tried it yet?
Yes using the 2.46 from Asrock website tonight, it works fine and took the XMP fine.
Previous beta from other sources was crappy as posted above.
2.46 seems decent. The boot speed is very fast now, BIOS screen appears very quickly and a few seconds latter the windows login screen.
All I had to do was copy my ram settings from 2.10. All voltages are stock auto, except the dram voltage. I did turn the LN2 option to disabled and PBO to disabled. No fan ramping at boot. Did not even have to setup the boot drive. Did not get the increase in all core clock speed.
