USB not detecting devices
17 Aug 2009
Finchley, London
Hi guys. On my laptop running Windows 10, I've got two USB 3.0 and two USB 2.0 ports. My USB 3.0 ports have always detected devices but now when I plug a device in such as my phone or a pendrive, they're only picked up by the USB 2.0 ports. I can only charge my phone or run my laptop cooler pad fans in the USB 3.0 ports.
This only started happening yesterday. I've updated the drivers for everything in the screenshot here, even uninstalled and reinstalled some of them.
Any ideas? Should there be a Renesas USB 3.0 eXtensible Host Controller in the list?
Nope, no exclamation marks or yellow triangles. I checked the bios yesterday and everything was enabled in the USB section, though nothing I recall specific to USB 3. If the USB controller board has failed, would it still be able to charge the phone and run the fan or would there be no power at all?
It is an older pc? I had a pci card with usb 3 on my old pc. That was a Renesas USB 3.0 eXtensible Host controller. Never did work in windows 10
Used to have that brand of controller (not sure on model of yours) but not sure if it was Win10 but go to "StationDrivers" and see if there is a Firmware and Driver for it as I updated both many times in the past.
No doubt he had DaemonTool installed.
I have marked red the ones on my PC that I think are also virtual , I have a Corsair AXi1600 and think the Corsair Link software installs the USB device for the readings to show in Windows.
Do you think my Daemon Tools USB bus is interfering with my USB 3.0?
Where would I locate the Station Drivers?
It's a Dell Latitude E6530. I bought it 2 years ago.
Thanks for the links. There's a couple of Renesas USB 3.0 driver and firmware downloads in your second link but I don't know which I need. There's
Renesas/Nec uPD720200/720200a and Renesas/Nec uPD720201/720202. Then clicking on either of those brings up several versions of firmware and drivers.
Driver Fusion wants me to buy the premium version before it will fix anything so that's no go. And I can't see anything in device manager to help me.
I own the paid version as it used to be Guru3D.coms DriverSweeper bumdeal for you though and I would not trust some of the similar software out there.
You need the Hardware ID from the Windows Device Manager and Google it and you will find out what your device is, there is only two choices AFAIR on StationDrivers and I am pretty sure mines was the one with the "a" at the end.
Thing is, there's no USB 3.0 eXtensible Host Controller in my Device Manager to get Hardware ID from. But if you think I need the one ending in 'a', there's these 3 files, should I install all of them?
It's possible that the USB 3 controller chip has failed. There's no fix for that.
What do you get if you enable Show Hidden Devices in Device Manager? Hopefully a silly question but you have been into the BIOS and checked that the ports are enabled, right?
Do you have another 2.5" drive? If so fit that and try to install Windows. You couldf also try running a live Linux from a CD or USB stick.
That's a good suggestion to show hidden devices. I did that and it showed these extra things, https://i.postimg.cc/ZRWMsNkB/show-hidden-devices.jpg
all of which when clicking on properties said:
"Currently this hardware is not connected to the computer
(Code 45)
To fix this problem, reconnect this hardware to the computer
I uninstalled those and they didn't return after scan for hardware changes or rebooting.
Now it looks like this while still showing hidden devices. But nothing has improved with my USB 3.0
https://i.postimg.cc/fWSBpXyZ/show-hidden-devices2.jpg
