Total War: Warhammer 2
Caporegime
8 Sep 2005
Utopia
3700x with 5700xt ,12gb ram all installed fresh on an M2 hard drive and x570 elite motherboard.
All drivers up to date .
All settings on ultra on dx11,AA to max basically what it recommended, it runs fine for a few minutes then it has drops in frame rate .
Also tried knocking shadows down AA etc all down to high and still no better...
Will have another play around with settings tonight
Sorted apparently shadows are a big deal so set all to ultra and just turned Shadows off. Works a treat.
Shadows cause an impact but really improve the graphics. Unfortunately, AMD CPU/GPU rigs also seem to run badly with TWW2 compared to Intel/Nvidia.
2 Mar 2009
Oxford
I had problems playing this game and crashes/freezes with a 2070 super, tested an rx 580 8gb and it worked fine (albeit lower FPS). Using a 3600X and actually found the AMD CPU/GPU setup more stable. I will look at the shadows stuff though - thanks.
28 Jan 2008
Manchester
Since the update I noticed the game being slower in menus. The actual game still runs fine for me but if I want to save/ load a game it takes few seconds to get into menu.
17 Apr 2009
Curse of the Vampire Coast is 50% off for the first time.
£7.49 is my buy price for the race packs. IIRC even at 50% off the DLC totals something like £60.
28 Jan 2008
Manchester
Heads up, this is on Steam for £13.59, I haven't played the original so I picked that up for £9.99 to play first, also on sale.
Just buy the 2nd one as well. You can play all the content from first plus it's improved. I bought it at the end of august and not played another game since.
31 May 2007
Bristol
This is a good shout, with the amount of time I can actually dedicate to gaming both would last me a far long while!
30 Nov 2005
Rotherham.
One of my HDDs failed last week, it was the one with my TW:WH 1 & 2 saves on it. Got a completed Empire campaign and a 150 odd hours in a Lizardmen/Seraphim campaign as well :(
18 Nov 2011
Caddington
FYI, Its not about time to dedicate. #2 IS the first game with extra races. Its played on the same map, Albeit larger, With more races and improved mechanics+tweaks. The only caveat is that you have to OWN #1 to be able to play as the original races in #2
28 Jan 2008
Manchester
How long "roughly" for each of the two types of games are your turns taking (say around turn 20) and is your game on a SSD?
ty
As mentioned it's down to CPU power. Plus there are other factors to consider. How many factions you encountered already and amount of their armies/ agents visible.
I'm 80ish turns into my tomb kings campaign and would say it takes about a minute. I run i5 4690k so quite old, think the OC is at 4.4ghz
