- 18 May 2010
- London
I have a friend (of a friend actually) who is 25 no GCSE's etc to his name and currently unemployed.
He is seeking a career path and I suggested IT as that's what I am doing.
At first I told him to look at doing the RHCSA and RHCE and then seeking a systems engineering role. But then I thought this might be a bit too high up for someone with ZERO experience. (Unless you count COD on the Xbox as experience)
As I started out in the industry with some Microsoft certs and then a low level 1st line support role, I thought that would be a good enough start for him. (I did have a degree and a master tho)
What do you think, start at the bottom with some MCP's and then move in to technical support and move up from there or go from A to C and try to get a Linux administration role via studying the RHCSA/RHCE and Ansible?
The other reason why I suggest the 1st line support is because he has nothing on his CV and no money. So really shouldn't spend the next 6-12 months just studying.
The quicker he is in a job the sooner he can start building up his experience hence the 1st line support avenue. It will be quicker to break in via this route than going for a higher up role with no experience in any IT capacity.
