When I can go from Lands end to John o’groats on one charge.
Not in our lifetime
Then never then.Not in our lifetime![]()
They only check if the ticket is expired or not there. They dont investigate every car. If the model also has an EV version it would be easy to fool people.
how do you know they don't ? - I just looked where I travel. - I'd check
that's 9 a day, on road i use
edit: 126 a day for ths small city !
How frequently do you do this trip?
The vast majority of non electric cars cant do it either, i cant think of a single petrol car that can, and more and more modern diesels are seeing the fuel tanks shrink, so there wont be that many of them either
There was a sweet spot when MPG went up, but they didn't reduce the tank size so range went up and up
They wont allow bus lane use. It would end up holding buses up which defeats the point of them.
in flight refuelling ? group of batterySir will be wanting the optional 10,000 kilo battery trailer with solar panels and wind turbines then?
But it only takes a few minutes to refill a petrol\diesel car.
in flight refuelling ? group of batterytankerlorries that trawl the motorway and you can fast charge on the go
High performance electric cars are brilliantly fun to drive. Enough petrolheads on YouTube etc. saying as much and I can absolutely attest to that. The instant torque is wonderful. If you get turned on by the sound of an engine or like cycling through gears then fair enough, but to claim electric cars aren't fun to drive is ludicrous (pun intended).
And until there is a standardised battery pack specification forced upon manufacturers, EV owners will continue to have to plan for lengthy recharging stops on longer journeys.
Technically possible, but has Sir considered the skill level of the average driver?
That is simply not true though is it? More and more vehicles are now being made that support 150kW+ charging rates, and some up to 350kW already.
You can stop for a toilet break and a take away coffee and if you plug in while you do that on a 150kW charger you'd have added 25kWh of energy back in to the pack in 10 minutes at the 150kW rate, or much more on the faster 250kWh+ chargers.
