2040 @ 45C assassins creed odyssey every thing maxed under volting is really paying off
Well so far the Zotac 2080 Ti blower is damn nice, Clean looking too IMHO being all black with a black metal backplate, No gamery angles, No flashing lights, Looks very professional and blends into my setup quite nicely, Had it running stable at 2000MHz/7750 on air with dips on the core down to 1900 with a 1:1 fan curve, Replaced the air cooler with a Corsair FE block and it now sits stable at 2050/7750, Very impressed so far.
What temps are you getting with the Corsair FE block? It's the Hydro X series right? They look pretty sweet.
Mine idles in the 27 range thermals are excellent .
Yep the HydroX, I left the fans on full which is around 1600RPM, Rad is 360mm dedicated to just the GPU, Idle temp under water is 19'c, Quite cold in my home, And temp after an hour of Unigine Valley is 42'c, Again, It's very chilly in my home.
Even on air the Zotac blower is really good.
Excellent results. I have x2 360mm rads and 2080ti shares the loop with 9900k. My temps are at least 10-15c above yours. I don't have the best temps. Not great, not terrible. 3.6 roentgen.
It's the first time I built a custom loop, so I am sure something isn't quite right. I have checked everything I can possibly check. Airflow, mounting, etc etc and I can't reduce temps any further.
I have fiddled with the system so much now, I am just going with the if it's not broke don't fix it route!
I've got a 360 and a 480 in my loop, cooling my 2080 Ti and 8086k. GPU idle is 26 or so, mid to high 40's under load. In demanding games and benchmarks it'll rise into the 50's.
My CPU always seems to be around 5-10 degrees higher idle and 10-15 degrees higher under load, I assume because it's an Intel and they're hot when overclocked.![]()
I don't get why people say no benefits to water cooking GPUs.
You can maintain max boost clocks, the same generally can't be said about air cooling.
Seems the 2080Ti really benefits and let's you get the most from it.
Pretty sure that invalidates the warranty!Well so far the Zotac 2080 Ti blower is damn nice, Clean looking too IMHO being all black with a black metal backplate, No gamery angles, No flashing lights, Looks very professional and blends into my setup quite nicely, Had it running stable at 2000MHz/7750 on air with dips on the core down to 1900 with a 1:1 fan curve, Replaced the air cooler with a Corsair FE block and it now sits stable at 2050/7750, Very impressed so far.
In trying to figure out if my card is scoring good, pointless using 3dmark hof, what did you get?Did Zotac email back about the extended warranty? I sent mine on the 20th very happy with the card almost doubled my timespy score.
You get the WB model?My gigabyte aorus extreme should arrive tomorrow!
