Need help! Spy camera?
24 Oct 2019
Hi,
I just discovered a tiny hole surrounded by plaster area size of 5p above my shower. I have a false ceiling above shower and the bathroom is downstairs.
I don't want to create a mess/hole by knocking it in as it's a rented property and if it is too small for it to be a camera then i would be daft to incur expenses i can ill-afford.
Can someone instruct on how to get a url address for the photographs on my fone so I can upload here for someone to have a look and please help/advise.
Thanks so much in advance for your time. I called a company but it is £1200 for them to do a sweep. I will knock the ceiling down before I have to have that kind of outlay.
Female with young child here.
A hole the diameter of a 5p coin is more than enough for a camera. Try poking something non-conductive into the hole (gently!) and see if it meets any resistance. If it does, put some glue on the end and let it set and pull the camera through.
You can use www.imgur.com for uploading photographs.
Edit: just a thought, but you could also get one of these, a wireless inspection camera which links to your mobile phone.
89J4W4y
[/url][/IMG]
Thx quartz... did any of those codes work? Igmur shut down but tried another... html/bbcode.
The 5p diameter is filled with plaster but theres a pin hole in the middle... could use a needle (but obv this metal)?
I have a clawhammer as well.
It's fine!! Thank u so much Quartz!!! Stuck a needle up - there is nothing there!!
I am a DV survivor and have been targeted in the past so my ptsd was off the scale.
Thank u so much.
Looks to be where the plaster board was secured to the ceiling you will probably find a fixing behind the bump.
