So... if the entire UK car fleet moved to EV, there would potentially be a vast reduction in the number of caravans?
I'm surprised Clarkson isn't singing their praises![]()
I'm waiting for some amazingly expensive luxury caravan to appear that has a Li-ion battery pack out of a car fitted to it, allowing it to be self powered or even draw power from your car if needs be, or the other way round.
Can you imagine, a van with a flexi solar roof, and inverter, and a large pack, actually using a caravan might then be bearable as you wouldn't need a hook up. They could fit a compact heat pump to it for heating and aircon it would be great.
