Call Of Duty: Modern Warfare / Warzone (Battlenet ID's in OP)
Man of Honour
13 Oct 2006
5700xt have a freeze or a pause for few seconds starting to annoy me getting killed most of the time. Then latency shoots up too 999, anyone else have this problem
I've seen multiple reports the game stalling for a second or so from people with various hardware so I'd imagine chances are it is a game issue rather than GPU related.
29 Dec 2007
Birmingham
Glad to see somebody mention this here. Is it anything like this https://streamable.com/31dmt & https://streamable.com/q6g4s ?
I'm using RX Vega 56 Pulse flashed to Vega 64 using a sapphire bios. Rest of the rig consists of Ryzen 3600, b450 tomahawk max, 16gb patriot viper steel at 3800mhz, corsair rmx1000i and the game is installed on my mechanical hard drive. Everything is updated to the latest drivers etc.
21 Oct 2013
Ild
I had that problem sometimes thee freeze would last for 30+ seconds. cpu usage was 100%, I changed some graphics settings and it plays "fine" now. (i7 7700k:5G and vega 64 ref)
14 Dec 2017
Aberdeenshire
Does anyone have this on console to? Was wanting to know if it synced across with the cross play? I've got up to level 29 on MP. Do I start back at 1 on the PC?
19 Jan 2019
Co. Down, N.Ireland
Yeah exact same issue here also same cpu and have b450 Pro carbon.
4 Oct 2011
Jersey
Had fun tonight, will be renaming myself HairyTeamKiller .....blinking hardcore mode :mad:
At least you don't get kicked for teamkills now! After 2 it just reflects all damage which is a much better way of dealing with it. I remember in Black Ops 2 if you called in a killstreak that did lots of damage to the map you would get kicked when your teammates ended up in the blast.
17 Feb 2015
Leighton Buzzard
If anyone wants a gamepad PC playing pansy, i'd be more than happy to join up and have my ID posted on the mainpage.
Activision ID: Dannyp27#2865 (not sure if the hash is needed)
