Lol how can you tell it's better if HDR isn't working?Right, HDR does not work. Game looks better without it anyway.
Averaging 65fps in the bench with all high settings.
Andi.
I'm kinda baffled why people are still using 3rd party Antivirus software when Windows 10 has everything you need and more when it comes to security ! from my experience all these 3rd party apps do is mess up and slow down your PC.
Just use Windows 10s built in defender and run a scan every now and then. Been doing this since release and its brilliant.
How the hell do you save?
Because it was running, but it was making the game behave erratically. It made the whole screen look dark and just not quite right. Much brighter and crisper with it off.Lol how can you tell it's better if HDR isn't working?
Andi.
I am just wondering how long this will take me to finish!
) The story itself is pretty damn long.
Pass.How the hell do you save?
Got through the intro but had to exit as I couldn't figure it out. Will it only save when you get to your camp or a certain location or sleep?
The save game option is a little hidden away, but you can find it by hitting the 'STORY' tab on the pause menu. From there there's a huge place to click on the left of your screen that gives you the option to save your game—you can't miss it.
That said there are some occasions in the game when you cannot save, such as the very beginning. Just make sure you dig through this part and you'll be able to save what you've done later on. Just make sure you do so before a big event is about to take place in the game, or you've gone through a big session without hitting save.
You can only save at certain times and hardly at all during the first chapter. Go to the Story tab after pause if you can save it will let you do so there. Auto save is also active.Pass.
I'm amazed at the poor performance figures. Yes its a big stunning world, but come on, a decent PC 2 or 3 times the power of current gen console should be running this well up over 60fps with high settings, even at 1440p on mid range mid to high end GPU's. Just look at the 2080ti even struggling.
Is there a difference between them though, is the one x running 4k but with lower textures or less eye candy?I'm amazed at the poor performance figures. Yes its a big stunning world, but come on, a decent PC 2 or 3 times the power of current gen console should be running this well up over 60fps with very high/Ultra settings, even at 1440p on mid range mid to high end GPU's. Just look at the 2080ti outputting numbers half of what I'd expect at the various resolutions.
Ahh cheers there it is
How is it running for you seeing we have very similar set ups?
I'm keeping shadows on medium for now. They look ok to me.
I am getting over 120 fps in UHD. Going to turn on some more settings later.
Pass.
Bios update needed on 570?
I'm amazed at the poor performance figures. Yes its a big stunning world, but come on, a decent PC 2 or 3 times the power of current gen console should be running this well up over 60fps with very high/Ultra settings, even at 1440p on mid to high end GPU's. Just look at the 2080ti outputting numbers half of what I'd expect at the various resolutions (maybe not 4k) but you get my point.
