- 18 May 2010
- London
Performance wise the best I'll get is the default balanced mode. I get a minimum of 33fps average of around 55fps on this default setting at 1440p.
I see the honour system is still a bit borked, came across a cowboy in the wilderness who started gobbing off at me to which my response was to defuse.... he pulled and shot at me so I obviously blew him away. Lost honour :/
Two wrongs dont make a right![]()
He would've killed me!Offset the blur with some sharpness within the Nvidia game filter thing. Basically press ALT F3 and add filters from there.
I added sharpness and it's a lot better.
I don't have Geforce experience enabled, can you do it through the standard NV control panel?
Has anyone had any weird problems with horse movement? For some reason if im riding at pace and try and move diagonally (IE hold W and A) my horse does a complete 180 rather than start moving forwards and to the left :/
Don’t use the presets. Customise them as per jokers video posted a page or two back.Performance wise the best I'll get is the default balanced mode. I get a minimum of 33fps average of around 55fps on this default setting at 1440p.
Could have found that advice on this thread much earlier.So after a couple of days of having the dreaded launcher crashing issue.
I followed advice I found on a reddit thread and updated the bios on my X570 board to F10a, and........it fires up first time.
Try changing the horse camera to "horse relative" or something like that
Its in the menu somewhere, I changed mine so I can press w to trot forward and spin the mouse around and the horse still moves in the same direction.
