Nice find, used these settings and I'm getting an average of 78 fps!
Tons of difference, limits shadhows no dynamic shadows.
I thought it was just me, bloody annoying that!That's because everytime you quit the game, your graphics settings reset to windows borderless! its such a pain in the.....
I got mine from cjs but chose the one for £42 where they send you a code otherwise they send you a R* account with the game on I think.
Question, are you guys using DX12 or Vulcan? Vulcan has been fine for me so far, so not seen any reason to change it.
I had to stop playing after 30mins as I was getting motion sickness
No idea what my frame rate is but must be low. What are people using to see there FPS as I couldn't see an option for one in game?
Guess I'll have to mess with graphics settings to get higher frames.
Not sure but if you have a look at these links, you be able to fine tune and get the settings you like best.Anyone have a good guide for 4k 60 please?
. Also whats up with load times, even with an nvme drive it takes a while, is it essentially loading the whole map at once?What kind of framerate are you getting with everything on low? It sounds like there might finally be a game that I can't get away with playing on high if you need gsync to smooth it out on low!Hi mate, I'm on a 980ti @ 1440p and Gsync saves me tbh.
My settings are all low apart from Textures but the game still looks awesome.
And then read through this article - Red Dead Redemption 2 Most Important Graphics Options - Every Setting Benchmarked
Then you can also have a look at this article, which is based on the article above. - Red Dead Redemption 2 PC – Performance Guide
That should at least help you some to get the settings you wanting.
