*** The Official OCUK Cinebench R20 benchmark Thread ***
Score 5321
Xeon E5-2699 v3
Not bad for a 2014 2.4ghz CPU, the 18 cores do help though :D
https://i.~ibb.co~/41dsFNM/Capture.png
Ah yes sorry I meant to write beat my 542 score not repeat it. :D
And yes that is 543 at 4.6Ghz
I suspect its the limit tbh as i simply cannot get more than 1 core happy at 4.65.
Did you have to run it a few time to get that score?
Maybe if I run it a few times I can get it also as I managed 4675MHz. Lol.
Humbug, hold out a few days if you want, I may be able to run it a few times and get that extra 1 point so you don’t have to do anything apart from change both our scores to 543 :p
Go on give it 1.5V and go for it you know you want to :D
At least yours will be a lot cheaper to replace and available!
Hahahahaha. Don’t think I would come across this kind of 3600 by the looks of it, judging by what I have seen here anyways.
Not doing 1.5v. Will just keep running 1.475v a few times until by luck that extra point pops up :p
Haha. Just did it. Uploading shortly.
Told ya not to bother humbug. Now you go run it again at 1.5v @Shac :p
10th place is mine!! Muahahaha :D:D:D
I have run it at 1.52V but only one core seems happy to run 4.65
It seems you need at least 2 cores the same setting on a CCX or it will not take.
I noticed that from day 1, that’s why I do all 3. Look at my picture.
Try giving it some more volts? ;):p
Yea thats why I said you have a better core.
If i try setting more than 1 core at 4675 it hard resets even with 1.52V and I am not trying more than that.
Of course until you get better than 543 your still only sharing best Ryzen score (desktop) :p
Don’t worry, give it a few more days and it will slowly eat at you bit by bit and you will up the core to 1.55v for another attempt :p
If it was April 1st I would have made a post saying I blew up my 3600 trying 1.5v. You would get a huge laugh out of that no doubt. Schadenfreud. Haha.
