DDR4 at 2666MHz or 3200MHz for i5 9600KF
20 Aug 2010
I am upgrading my PC and have gone for the i5 9600KF and I am looking for memory to go with it. I notice on the processor specs it lists DD4 2666MHz ram but I can find some DDR4 3200MHz for the same price as the 2600MHz. Am I better going for the 2666MHz or the 3200MHz, will the 3200MHz ram work with the i5 9600KF?
Man of Honour
8 Nov 2007
Outer Space
Yeah that's fine, 2666MHz is just the industry standard rating, so the 3200MHz is officially overclocking but Intel CPUs normally play nice with faster RAM :)
OP
20 Aug 2010
Thanks, I will order the faster stuff then :) Can I go faster than 3200MHz or is the extra cost not worth it?
16 Jun 2004
Thanks for the advice, I decided on the 3200 in the end.
That's good to know I went for the 3200 :)
Don't forget to try overclocking it, I would be very surprised if it didn't reach at least 3600Mhz, you might need to increase voltage to 1.4vlts (perfectly safe).
My Vengeance Pro kit is actually a 3000Mhz set but runs perfectly stable at 3466Mhz (1.4vlts)
22 May 2010
Minibotpc
Did you notice any gains in FPS while gaming with the increase in mhz?
5 Aug 2006
Derbyshire
That will be totally dependent on the game.
I would not bother overclocking the ram as I found it required a lot of patience and fiddling, but it was back on AMD64 that I last tried (Jesus that was DDR1 400mhz!).
I think 3200 was a wise choice over 2666 given the minor price difference.
Definitely overclock the CPU though!
