Problem after installing M.2
2 Aug 2017
So i have b350-f Motherboard and decided to add an M.2 (970 EVO Plus) to my PC. I bought it. Pluged it in and now my OS will not launch. It goes straight to BIOS every time. What am i doing wrong.
OP
2 Aug 2017
Ok so i think what is happening it stopped reading my SSD which i have my OS on.
I have an hdd, ssd and now m.2. And it only sees hdd and m.2.
Edit: when i unplug m.2 its all good. No idea what to do
18 Oct 2002
Manchester
When you use an M.2 SSD it shares bandwidth with SATA ports 5 and 6 according to the manual. So it might, to all intents and purposes disable your SSD. You need to try moving the sata connector to ports 1 through 4 and re testing. I imagine this will resolve the issue.
1 Apr 2014
Aberdeen
Have you checked the boot order in the BIOS? Likely it's preferring the M2 drive over the SSD.
