Pfsense - access Draytek Vigor 130 GUI
12 Feb 2008
Shropshire
I'd like to be able to access the GUI of the Draytek Vigor 130 I'm using. I've tried to follow this guide:https://webcache.googleusercontent....+&cd=6&hl=en&ct=clnk&gl=uk&client=firefox-b-d, but I'm getting stuck where it's saying "add a new interface using the same physical interface that your WAN connection uses". If I do that, there's just a message about 2 interfaces on 1 and then doesn't allow me to.
WAN is on igb0
LAN is on igb1
MODEMACCESS (OPT1) is on igb2
If I try to assign MODEMACCESS to igb0, that's when it comes up with:
The following input errors were detected:
Port igb0 was assigned to 2 interfaces: WAN (WAN) MODEMACCESS (OPT1)
From other guides, they all seem to show the WAN interface as PPPoE, where as mine is DHCP (Sky broadband). Not sure if that is significant or not.
I had this as well, you need to set up the modem interface as a PPPoE link instead of what you have at the moment.
Its not very well described and i dont have my VM with pfsense working at the moment as i am soon to move the server its on (when i can be arsed running wiring!)
Is it "MODEMACCESS igb2" that I need to make PPPoE?
Just create a ppoe link afresh using one of your nics ports, its in the vlans menus somewhere (like i said i aint got mine on at the moment so trying to remember this from a hazy memory)
You will need to go into the dray and set it to ppoe ect but thats well documented on the web.
Your sky broadband router is then tossed as it serves no use, i assume they gave you the password for your connection - i left vodaphone in a huff because they wouldnt.../ would.../ wouldnt... / would ... give me mine.
I'm on plusnet with a pfsense router and a Draytek 130 - by accessing the Draytek GUI you can do the SNR tweak for more speed :)
1. Create an interface on em0 (or whatever lan interface your Draytek 130 is on) named modemaccess, give it a static ip of 192.168.2.2.
2. Change outbound NAT mode to hybrid and create a new outbound rule.
3. Set the Interface in the rule to modemaccess
4. Set the source in the rule to the same subnet as your primary lan subnet (192.168.0.0/24 in my case)
5. Set the destination to 192.168.2.0/24
6. Set the Translation address to 'Interface Address' and save
Test and it should work fine.
Thanks. I’m probably being dumb but, how do I create another interface on an existing one? The rest of it I can do no problem. Annoying thing is, I’m sure I’ve done this before but just can’t remember how I did it lol
I have the same issue as you.. have had similar set-up for 2 years and could never get access to my modem to work with Pfsense
When i go into assignments the only option I have is to assign unused interfaces. I cant use the same network port to anything other than Wan or Lan
Do you have a spare physical interface on your pfSense box, and a managed switch? If your connection doesn't use PPPoE then that's the only way I can think of to get this working.
What would fix all this instantly would be if DrayTek had an option to run the management on a VLAN tag.
I only have 2 nic ports on mine one assigned to LAN and one assigned to WAN
because SKY uses MER for authentication you have to set the set-up as DHCP and not PPPOE
I’ve got another 4 physical interfaces/ports I can use but I don’t have a managed switch. A user on Reddit has suggested I do it using a VLAN: https://www.reddit.com/r/PFSENSE/co...urce=share&utm_medium=ios_app&utm_name=iossmf
Guessing that does need a managed switch then?
Apologies I missed that you were using DHCP on the WAN instead of PPPoE, have you just tried the NAT rule pointing to the WAN interface igb0 instead without creating another interface? This assumes you are double nat'ing and your WAN address is 192.168.2.x?
No problem, I think the ISP I was using when I did this last time was using PPPoE. I don't think I'm double NAT'ing. Setup is Vigor 130 > Pfsense > TP-Link Gb POE switch > Clients. I've tried the suggestion from the user on Reddit but can't get it working. I don't know if that's because I don't have a switch that does VLANs. I notice there's an option for VLANs in Pfsense but I don't know how to set that up or if it's the right way to do it.
@Jon20 I think I replied to your post on reddit with some screenshots of my setup, were they any use?
Ah Andy, I knew I'd seen the username before :) I've just copied your settings from the screenshots but unfortunately, still can't access the GUI. I notice you have a managed switch, was just wondering if that's required?
I'm pretty sure it is required yes. I certainly could not make it work without vlans. I think I have the modem port untagged vlan2, and the pfsense wan port tagged vlan2 (HP switch). Its quite handy as my modem is under the stairs and the pfsense box in another room, so a single cable can handle wan and lan connections.
