Caporegime
- 7 Apr 2008
- Lorville - Hurston
Hi all, i recently upgraded my home network to 10Gbit but i dont get this speed
TD:LR
Two devices have 10gbit network adapters and between the two i get max 2gbit speed.
My windows based laptop with wifi 5 gets around 30/60mpbs
Below is my Network devices and how it is connected
my isp > Netgea R7800 router > Netgear 10-port/10G switch(GS110EMX) > (windows deskto pc/ ubuntu linux desktop server)
Specs of the machines:
Desktop windows PC.
3x SanDisk ultra 960GB sata 3 hdd
ipolex 10Gb PCI Express Network Card for Intel X550-T1
Ubuntu server 18.0.4
Crucial m500 240gb ssd hdd(OS installed on it)
2x WD Red 3.5 6TB hdd's
2x WD Red 3.5 3tb hdd's
Laptop Thinkpad x1 extreme:
2tb Samsung 970 evo
Intel(R) Wireless-AC 9560 160MHz
The desktop pc is connected to the negtear 10gb switch using a cat 8 cable thats 2m long and the ubuntu server desktop is also connected to the same switch using a CAT8 cable.
A single Cat 5e cable is used to connect the switch to the netgear router that handles dhcp for all my network attached devices.
When i transfer some files located on one of my Sandisk SSD hdd and transfer it into my ubuntu server i get only between 1-2gbit speeds only.
Is this due to hdd bottleneck on the windows pc or in the ubuntu server?
Would i only get the full 10gbit speed if i had a m.2 nvme hdd attached to both the windows pc and ubuntu server?
Does the data between this transfer goes through my negear router and then back onto the switch that may cause the delay?
Wifi speed is also slow even when the laptop is right next to the router and has a wifi 5 card that should be capable of 1gbit speeds
TD:LR
Desktop windows PC.
2tb Samsung 970 evo
